Are These Expressions for Probability Current Density Equivalent?
qwijiboo
Hi folks!
Can someone tell me how to solve the following... I'd really appreciate it.
Show that the below two expressions for probability current density are equivalent.
j(r,t) = h'/2im(\Psi^{*}\Delta\Psi- (\Delta\Psi^{*})\Psi]
j(r,t) = real part of [\Psi^{*} (h'/im) \Delta\Psi]
h' is the reduced Plancks constant h/2pi
You should really give us your thoughts (or at least a guess) on this. But if c is a complex number, what's the relation between Im(c) and Re(c/i)? And you may also want to think about integration by parts.
I'm sorry... but I figured it out. Its a pure math problem. Sometimes my brain just ceases to work!
RP of the second equation is {j(r,t) + [j(r,t)]*}/2 substituting ,we get the first equation.
Thanks anyways for replying to my post.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
