Area between two curves problem
  • Thread starter Thread starter calculusisfun
    Area Curves
calculusisfun
(a) Find the area A, as a function of j, of the region in the 1st quadrant enclosed by the y-axis and the graphs of y = x ^ (1/3) and y = j for j > 0.
(b) What is the value of A when k = 2
(c) If the line y = k is moving upward at the rate of 1/2 units per second, at what rate is A changing when k = 2?
2. The attempt at a solution
Ok, so I doubt this is right as I was really, confused, but this is what I did...
(a)
x^(1/3) = j
x = j^3
A(j) = integral of (j - x^(1/3))dx from 0 to j^3
(b) A(2) = integral of (2 - x^(1/3))dx from 0 to 2^3
this equals = 4
(c) I have no idea..
I took the derivative of A(x) and got zero...
Please help. :)
You computed corretcly the Area, which is a function of ? (name it)
If j changes, and you have a certain function of j, how do you compute the change of f(j) ?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
