How Do You Calculate the Camera's Velocity in an Astronaut Momentum Problem?
In the astronaut momentum problem, momentum conservation is key to finding the camera's velocity after the astronaut tosses the oxygen tank and camera. The total initial momentum is zero since the astronaut and objects are initially at rest. After the toss, the momentum equations are set up separately for the x and y axes, incorporating the known velocities of the astronaut and tank. The equations allow for solving the camera's velocity as a single unknown, despite initial confusion about multiple unknowns. Properly resolving the momentum components and ensuring correct signs are crucial for accurate calculations.
xXmarkXx
A 60kg astronaut floating in space simultaneously tosses away a 14-kg oxygen tank and a 5.8kg camera. The tank moves in the x direction at 1.6 m/s, and the astronaut recoils at .85m/s in a direction 200degrees counterclockwise from the x axis. Find the velocity of the camera.
I can't find a way to start off this problem. I drew a diagram and everthing.
Well, you know momentum must be conserved. So what is the total momentum before the toss and after? Find the expressions for each direction.
The total momentum before the toss = 0 because there is no velocity.
After the toss,
Ptotal=Pastro+Ptank+Pcam
Resolve the momenta into components.
mtotvtot=mastrovastro+mtankvtank+mcamvcam
like that?
like that?
Nope, along the x and y axes.
Since the total momentum is conserved, they must be conserved along the axes, too. So
initial momentum along x-axis = final momentum along x axis. Similarly for y.
x: mtvtx=mavax+mcvcx+mtankvtankx
y: mtvty=mavay+mcvcy
i think this is what you mean right?
Yes, that's right.
Make sure you get the signs right when putting in the values of the velocities.
neutrino said:
Yes, that's right.
ok, so I'm solving for the velocity of the camera but i don't have the total momentum, so how can i solve for the camera's velocity with two unknowns?
What two unknowns? Read the question again. There's only one unknown per equation, and you can solve for them with the given info.
Total momentum, and then the final velocity for the camera.
Can i say
-mavax=mcvcamx+mtankvtankx ?
Sure you can. The initial momenta along both directions is zero, remember?
right, but i thought i was solving for the final velocity
Yes you are. It is because of the zero initial momentum (mtvtx = mtvty = 0) that you are able to write the equation as your previous post.
can u say ( also have this problem, and this is how i was working it out)
m_ast*v_ast*cos(200) + m_tank*v_tank + m_cam*v_cam*cos(20) = 0
these two equation actualy equal each other (produce same answer)
all withrespect to the x axis
can someone explain...
why do you have to use the y-axis or even worry about the x-axis in this problem... you can relate teh whole thing to the x component w/ trig?
