Astronaut throwing a Wrench in space problem again
An astronaut drifting away from his spaceship at 0.20 m/s needs to throw a 0.50-kg wrench to return. The conservation of momentum equation is crucial, but the problem lacks clarity on whether the wrench's mass is included in the astronaut's total mass of 90 kg. The goal is to determine the minimum speed at which the astronaut must throw the wrench to achieve a speed of 0.10 m/s towards the spaceship. There is confusion regarding the correct application of the momentum equation and the signs used in calculations. Properly addressing these points is essential for solving the problem effectively.
jmattsen
An astronaut with a mass of 90 kg (including spacesuit and equipment) is drifting away from his spaceship at a speed of 0.20 m/s with respect to the spaceship. The astronaut is equipped only with a 0.50-kg wrench to help him get back to the ship.
conservation of momentum m1*v1=m2*v1
unfortunately i really have no good an attempt. i know that the Δv has to = 0.1
and that the wrench has to exert a force on the astronaut in the opposite direction he is traveling but what i do not get is how the conservation of momentum equation is used since all the variables are known? (90kg+.5kg)(.2m/s)=(90ks)(.1m/s)
i feel like i should be using the equation F=m*Δv/t since i need to get a Δv in it somewhere but beyond that i am stumped
Hi jmattsen, Welcome to Physics Forums.
Your problem statement is vague or incomplete. You haven't specified precisely what is to be determined, and in what reference frame it is to be given. Presumably you need to find the minimum speed that the astronaut needs to throw the wrench in order to return to the spacecraft , but is that speed to be with respect to himself or the spacecraft ? And is the wrench's mass included in the astronaut's "spacesuit and equipment", or is it to be counted separately from that 90 kg?
whoops, i forgot the other half of the question.
With what speed must he throw the wrench for his body to acquire a speed of 0.10 m/s?
That's the correct approach but where is the term for the spanner? and check your signs.. Your equation says the astronaut is still moving away from the ship, just slower than before, he's still in trouble! The question doesn't say it explicitly but I'd assume he wants to throw it fast enough to start moving back towards the ship.
