At what point along the x axis is the electric field zero?
The discussion centers on finding the point along the x-axis where the electric field is zero due to two point charges, -9.10 μC at x = 0 cm and 21.29 μC at x = 8.00 cm. The user initially believes the zero field point is to the left of the first charge, leading to a negative x value. However, confusion arises regarding the correct formulation of the distances in the electric field equations, particularly the use of x + 8 for the second charge. Ultimately, the user is encouraged to reconsider their calculations, especially the implications of the negative x value on the distance to the second charge.
A14
Moved from another forum, so homework template missing
Hello, I've been trying to answering this question but my answer is always wrong.
Two point charges, -9.10 μC and 21.29 μC, are placed at x = 0 cm and x = 8.00 cm, respectively.
(a) At what point along the x-axis is the electric field zero?
What i did: i figured that the point should be on the left of the first charge, so before x=0 (should be negative).
Then i resolve E1 + E2 =0
kQ1/r^2 + kQ2/r^2 =0
(-8,19*10^4)/(x^2) + (1,916*10^5)/((x+8)^2) = 0
(8,19*10^4)/(x^2) = (1,916*10^5)/((x+8)^2)
1.916*10^5*(x^2) = 8,19*10^4 ((x+8)^2)
Then i develop and get x1= 1.51*10^1 or x2= -3.16
What am i doing wrong??
Thank you for your help!
Why is one denominator x+8 instead of x-8?
Is this a homework problem?
I don't know, for me as it is on the left of Q1, the distance to Q2 would be x (distance from point to Q1) + 8 (distance between Q1&Q2)?
Yes it is a homework problem!
Yes i see why it has to be negative (it has to be on the left of Q1 which is at x=0)
But -3.16 is not the right answer..
Think again about that x+8. With x=-3.16, what does that make x+8?
