Atwood Machine Help: Problem 1 Harvard
The discussion revolves around a physics problem related to an Atwood machine from a Harvard homework assignment. The main equation referenced is f=ma, alongside the principle of string conservation. The user expresses confusion about the relationship between the tension in the strings and the overall setup of the problem. They seek assistance in understanding how to approach the solution effectively. Clarification on the specific question is also requested for better guidance.
coppersauce
http://isites.harvard.edu/fs/docs/icb.topic725237.files/problemset3_2010.pdf (Problem 1)
f=ma, string conservation
I'm not really sure how to do this. I know that the t of the string on the left is equal to the two strings in the middle, and... I'm just kinda confused... Any help?
the question is not shown(i need to have an id ) .. can you write your question here ..
