How Does Oscillator Frequency Affect the Energy Ratio K/E?
The discussion focuses on deriving the ratio of average kinetic energy (K) to average total energy (E) for an oscillator in terms of the dimensionless quantity ωo/ω. The user has identified the expressions for K and E but is uncertain about calculating their averages over a specific time period. Suggestions include averaging K and E over the intervals where K is zero, specifically from t1 to t2, and using trigonometric identities to simplify the integrals of sin² and cos² functions. The user seeks clarification on applying these integrals to derive the final ratio, which is expected to be 1/[1 + (ωo/ω)²]. Further input on solving the integrals and confirming the approach is requested.
theuniverse
Express the ratio of the average kinetic energy K to the average total energy E of the oscillator in terms of the dimensionless quantity ωo/ω.
I found that:
K = (1/2)mA^2ω^2 sin^2(ωt − δ)
E = (1/2)mA^2[ω^2 sin^2(ωt − δ) + ωo^2 cos^2(ωt − δ)]
I know that my answer should be 1/[1 + (ωo/ω)^2].
I also found out that the total energy at the frequency of ω=ωo is: E=(1/2)mA^2ωo^2 (resonance) and I think it somehow relates to this problem.
I'm not quite sure how to reach the answer itself, or to make it more clear - I don't know how to come up with the terms for average K and average E.
Can anyone explain it to me?
Thank you for you time.
hi
basically, you can average over some time period. for example
K_{avg}=\frac{\int_{t_1}^{t_2}K(t)\,dt}{\int_{t_1}^{t_2}dt}
so how do you get t1 and t2 ? you can see that for
t=\frac{\delta}{\omega}
K is zero and again for
t=\frac{\pi+\delta}{\omega}
K is zero again. so we can let
t_1=\frac{\delta}{\omega}
and
t_2=\frac{\pi+\delta}{\omega}
which is the next value of t when K becomes zero. similarly you can average the total energy over the same range
E_{avg}=\frac{\int_{t_1}^{t_2}E(t)\,dt}{\int_{t_1}^{t_2}dt}
and then finally take the ratios...
I tried to take the integral of the energy expressions I had but the substitution of the t's became very complicated, so I was wondering, does integral [sin^2(ωt − δ)] and integral [cos^2(ωt − δ)] evaluated on the interval of t2 and t1 have a specific solution?
I know that the integral of [sin^2(ωt − δ)] over any complete period of oscillation T is equal to T/2. However I am not sure how to apply this to my problem.
I'd appreciate any further input.
use trigonometric identities to solve the integrals
\sin^2(\omega t-\delta)=\frac{1}{2}\left[1-\cos\,2(\omega t-\delta)\right]
and similar one for the other\cos^2(\omega t-\delta)=\frac{1}{2}\left[1+\cos\,2(\omega t-\delta)\right]
