Calculating the Average Kinetic Energy of a Helium Atom at 20°C
  • Thread starter Thread starter jgens
    Atom Average
The average kinetic energy of a helium atom at 20°C can be calculated using the equation E = 3kT/2, accounting for three degrees of freedom in translational kinetic energy. An initial calculation yielded 6.1 x 10^-21 J, but the correct value is 4.0 x 10^-21 J. A simpler approach involves calculating kT directly, which aligns with the correct answer. The discussion highlights a misunderstanding in applying the degrees of freedom in the kinetic energy formula. Clarifying the calculation method is essential for accurate results.
jgens
What is the average kinetic energy of an atom of helium gas at a temperature of 20 degrees C?
N/A
Here's my attempt at a solution: Using the equation E = kT/2 for each degree of freedom, I found that KE = 3kT/2 since an atom of He has three degrees of freedom in translational KE. Using this logic I fould that KE = 6.1 x 10^-21 while the correct answer should be 4.0 x 10^-21. Can someone help me understand where my logic/reasoning is incorrect? Thanks.
Looks okay to me. Someone got the 4.0 answer by just finding kT.
That's what I thought my teacher might have done. Thanks!
