Calculating Average Speed and Velocity for a Honeybee's Round Trip
  • Thread starter Thread starter ugkwan
    Average
The honeybee travels a total distance of 12 km during its round trip, with a displacement of 0 km since it returns to the starting point. Average speed is calculated as total distance divided by total time, resulting in 12 km/20 min, which can be converted to 1 km/min or 1000 m/min. Average velocity, defined as displacement over time, is 0 km/20 min, leading to an average velocity of 0. The discussion highlights the importance of using appropriate units for clarity, suggesting conversion to meters per second for a more standardized measurement. Understanding these concepts is crucial for accurately calculating speed and velocity in physics.
ugkwan
A honeybee leaves the hive, flies in a straight line to a flower 6 km away in 10 min, and then takes 10 minutes to return (also in a straight line).
a.) Please find the distance traveled and displacement for the entire trip:
distance travelled:
I know the distance total is 12 km
displacement: 0
b.) Please find the average speed and average velocity for the entire trip:
average speed:
This is where I get confused. Total distance/rate of change in meters = Average speed. This would mean the speed is undefined.
average velocity:
Same confusion because the algebra would mean this question is undefined with a displacement of zero.
Velocity = distance / time. As long as your time is not zero, it is defined. It's only the denominator that needs to be non-zero.
The average speed is the total distance traveled divided by total time spent traveling.
The velocity is similar, only it involves the total distance traveled in a direction - that is, the velocity on the way back will be the same as on the way out, only negative.
Thanks for the correction. I now see that I had the formula wrong. So it is displacement over time, and time is 20 minutes. So velocity is 0/20 and speed is 12/20.
That is correct, but they're funny units (kilometres per minute?).
To change to a more physics-y, SI unit, try metres per second:
(12km*1000 m km^-1)/(12mins*60 s min^-1)
=12000/720= whatever it is.
They do that deliberately: that is phrase the question in unweildy units, this makes you render more applicable units by the simple fact of expedience.
