Ball suspended in a horizontal electric field
A table tennis ball with a mass of 10g and a charge of 0.04 micro Coulombs is suspended in a horizontal electric field, causing it to shift 1.5cm from its vertical line of suspension. The discussion centers on calculating the electric force acting on the ball and the magnitude of the electric field. The relevant formulas include the electric force equation E=F/q and the gravitational force equation weight = mg. Participants emphasize the importance of considering both the gravitational force and the tension in the thread, noting that the weight cannot be neglected as it balances the vertical component of tension. A diagram is suggested to aid in visualizing the forces involved.
cdriscoll
A table tennis ball of mass 10g carries a charge of 0.04 micro Coulombs. It is suspended at the end of a rine threa 25cm long and placed in a horiztonal electric field. The effect of the field is to move the ball's centre 1.5cm to on side of a vertical line through the point of suspension.
What is the force on the tennis ball?
What is the magnitutde of the electric field?
I'm not even sure how to start this one so any help would be really appreciated!
What is the formula for the electric force on a charge q due to an electric field E?
F= k q(1) q(2) / d^2 ?
That's the magnitude of the force one charge exerts on another.
The question asked by grzz was
"What is the formula for the electric force on a charge q due to an electric field E? "
E=F/q ?
cdriscoll said:
E=F/q ?
Good enough.
How much is the force of gravity, which is downward. ?
9.8m/s/s...?
I'm really sorry I've been taking ages to reply I am so busy, but my assignment is due tomorrow so I'm screwed anyways... thanks for trying sorry I am so bad at physics :( if you still want to try and explain though that would be good i just might be slow replying, school starts tomorrow
Now check whether the gravitational force is negligible compared with the electric force.
cdriscoll said:
9.8m/s/s...?
That's the acceleration due to gravity, g. The force due to gravity is the weight = mg .
The force due to gravity (the weight) is downward. You are given the mass, so you can calculate this.
The electric field is horizontal, so is the electric force.
The tension in the fine thread must cancel both of these. The tension (also a force) is along the same direction as the thread.
I am revising my one suggestion.
The weight CANNOT be negligible because the weight must balance teh vertical component of the tension.
A diagram IS ALWAYS HELPFUL.
Try finding the components of the weight in the verical and in the horizontal.
