Ballistic Pendulum initial velocity of bullet
The discussion revolves around calculating the initial velocity of a bullet using a ballistic pendulum setup. A 20.0g block swings to a height of 5.00cm after a 0.50g bullet embeds itself in it. The potential energy of the pendulum is calculated using U = mgh, resulting in 9.8 Joules. The kinetic energy equation is applied to find the bullet's speed, yielding a final velocity of approximately 62.6 m/s. Concerns are raised about the assumption of work conservation in this scenario, indicating a potential error in the calculations.
MathHelpa
A ballistic pendulum is used to measure the speed of a bullet fired from a gun. The pendulum consists of a 20.0g block hanging from a string. A bullet, with mass 0.50gg, imbeds itself in the block causing the block to swing up to a height of 5.00cm. Find the speed of the bullet as it leave the gun.
W_nc = ΔK + ΔU
K = 1/2 mv^2
U = mgh
W = Fdcos∅
p = mv
I wanted someone to double check my work, and if I used correct units or not.
pendulum
U = mgh
U = (20.0g)(9.8)(0.05cm)
U = 9.8 Joules (this is not gravity it is what mgh came out to)
bullet
K = 1/2 mv^2
9.8(U of pendulum) = 1/2(0.005)v^2
v^2 = 9.8/0.0025
v^2 = 3930
v = 62.6099
v = 62.6 m/s
The bullet EMBEDS itself in the block.
In case you don't understand the significance of voko's comment, you have assumed work is conserved. That is unjustified (and quite wrong here).
