Is V0 the Voltage Drop Across R1 or R2 in a Voltage Divider?
In a voltage divider circuit, V0 is defined as the voltage drop across R2, not R1. The confusion arises from the direction of conventional current flow, which moves from the positive to the negative terminal. The connection from the negative terminal to the bottom of R2 is typically considered to be at zero volts, reinforcing that V0 corresponds to R2. Understanding this concept clarifies the role of each resistor in the voltage divider. The discussion emphasizes the importance of correctly identifying voltage drops in circuit analysis.
tylerc1991
This is more of a theoretical question than an actual numerical problem (so mods please move if this is in the wrong place).
The circuit below was copied from my book. Ultimately we are discussing the voltage divider. The book goes on to say that V0 is the voltage drop across R2. But I thought that conventional current flows from the positive terminal to the negative terminal. This would mean that V0 is the voltage drop across R1, right? Is it the voltage drop I have confused or the voltage divider? or both? Thank you for your help anyone!
The conductor connecting the negative terminal of the battery with the bottom of R2 is commonly considered to be at zero Volts. Thus, V0 is equal to the voltage dropped across R2.
