What Is the Correct Electric Field Calculation for a Dipole at Its Midpoint?
To calculate the electric field at the midpoint of a dipole consisting of two charges of 6.0 x 10^-12 C separated by 5.0 cm, it's crucial to use the correct formula and approach. The electric field should be calculated by summing the contributions from each charge at the midpoint, rather than using the charge squared in the equation. The distance (r) used in the calculation must reflect the distance from each charge to the midpoint, which is 0.025 m. The correct total electric field at the midpoint is approximately 1.7 x 10^2 N/C, taking into account the direction of the fields from both charges. Understanding vector addition is essential for accurately determining the resultant electric field in this dipole arrangement.
Arg3n
i Can't seem to get the right answer :
A Particular dipole consists of two charges of magnitude 6.0 x 10^-12 C. If the charges are sperated by a distance of 5.0 cm, determine the size and direction of the electric field at the midpoint between the charges.
E= Q / [4(3.14) x (8.85 x 10^-12) x r^2 ]
E= [(6.0 x 10^-12)^2] / [4(3.14) x (8.85 x 10^-12) x (0.05)^2]
= 1.29 x 10^-10
but the answer is 1.7 x 10^2 N/C
So i mut be missing something or I am just doing it all wrong
Your equation is not consistent throughout your calculation (you go from Q to Q2).
You are trying to find the electric field at the midpoint between the charges; not at the location of one charge (so the r value you are using is wrong).
You must sum up the contribution from each charge at the midpoint.
Thanks for the reply but I am having trouble understanding the whole charge concept, how do we sum up the contirbution of each charge?
Take the electric field due to a point charge equation: E = kQ/r2
This is a vector, so the total electric field at the midpoint will be Etotal = E1 + E2
It's a dipole arrangement, so one charge is negative and one charge is positive. This tells you the direction of the electric field due to that charge.
See http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elefie.html#c2
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
