Calculating Static Spring Deflection in Basic Harmonic Motion
To calculate the static spring deflection for a 10kg mass on a spring with a constant K of 2.5 kN/m, first determine the force exerted by the mass using F = mg, which equals 98.1 N. The static deflection can then be found using Hooke's Law, where the deflection (x) is calculated as x = F/K. This results in a static deflection of approximately 0.03924 meters or 39.24 mm. Understanding the relationship between kinetic and potential energy in harmonic motion can further aid in analyzing the system's behavior. The calculation of static spring deflection is essential for understanding the dynamics of oscillating systems.
Leiws25
A 10kg mass is suspended from a spring which has a constant K = 2.5kn/m. At time t=0, it has a downward velovcity of 0.5m/s as it passes through the position of static equilibrium. Determine the static spring deflection.
I believe i first need to calculate the force which requires basic trig. However I am unsure how to do that. I really just need some pointers in the right direction. Thanks in advance!
Hint on how I'd do it... An oscillating spring trades KE and PE.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
