Calculating Focal Length of a Drop of Water
To calculate the focal length of a spherical drop of water with a radius of 4mm and a refractive index of 4/3, the lensmaker's equation is recommended over the thin lens equation. The initial attempt using the thin lens equation yielded an incorrect focal length of 16mm, while the correct answer is 6mm. It's important to note that the radius of curvature for the far surface should be considered negative in these calculations. The discussion emphasizes the need for careful application of optical formulas in this context. Understanding the properties of ball lenses is also highlighted as relevant for practical applications.
thereddevils
What is the focal length of a drop of water in the form of a sphere with radius 4mm given that the refractive index of water = 4/3
Here, i think i will need to assume that the light rays are coming from infinity, and using this formula
\frac{n_1}{u}+\frac{n_2}{v}=\frac{n_2-n_1}{r}
n1/u is 0. Substituting n2=4/3 and n1=1,r=4, i got v=16 and for distant light rays, image distance equals the focal length.
But i am wrong, the answer given is 6mm.
It is possible that the formula you used is not applicable to this situation. When I use the lensmaker's equation (which seems like a natural thing to use), I get an answer that is close but not quite equal to the answer you have been given.
http://en.wikipedia.org/wiki/Lens_(optics)#Lensmaker.27s_equation
If I use the thin lens equation (which is just below the lensmaker's equation in that article), I get the answer that you've been given in your solutions. HOWEVER, I do not think that the thin lens approximation applies here, so really you should be using the lensmaker's equation. It's possible that whoever made your solutions incorrectly applied the thin lens equation to this situation.
EDIT: In applying these formulae, keep in mind that the radius of curvature of the far surface should be negative.
A sphere is known as a ball lens in optics - it;s very useful for coupling light into fibres for example. http://www.edmundoptics.com/technical-support/optics/understanding-ball-lenses/
See http://spie.org/x34513.xml for a derivation
Thank you.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
