Basic projectile motion question
A ball thrown on a level field with a range of 15 m can reach a maximum height of 7.5 m when thrown vertically, assuming this range corresponds to the maximum attainable range with the given velocity. The velocity calculated for this scenario is 12.1 m/s. The relationship between maximum range and height can be understood through the formulas for projectile motion, where maximum height is half of the maximum range. This relationship allows for solving the problem without directly calculating the velocity. Understanding these equations clarifies the connection between range and height in projectile motion.
gorays1414
If I can throw a ball on a level field with a range of 15 m, how high would the ball travel if the same throw was made vertically?
Using the range equation, I found the velocity to be 12.1 m/s, and the final answer to be 7.5m. Is this correct?
Yes it is 7.5m assuming 15m is the maximum attainable range with that velocity.
P.S: You could have solved this question without finding the velocity (I think you get it)
Regards!
ADI
Regards!
ADI
How could you have solved without finding the velocity? I get that there must be some type of relationship between the height and the maximum range, but I'm not sure I understand exactly what it is.
The formula for maximum range of a projectile motion is \frac{u^{2}}{g} ('u' being the velocity) whereas the maximum attainable height by a ball thrown vertically upwards = \frac{u^{2}}{2g} (This can be derived using the kinematical equations). So the latter is half of the former. Got it now?
Got it, thanks so much.
