Learn How to Solve Basic Statics Problems with Expert Guidance
  • Thread starter Thread starter HeartEngineer
    Statics
To solve basic statics problems, begin by ensuring that the tension forces at a specific point, such as point B, sum vectorially to zero. This means that the total forces in both the x and y directions must equal zero. If you are struggling to find the correct answer, it's crucial to share your attempted solutions for better guidance. Understanding the equilibrium conditions is essential for resolving the problem. Engaging with others who can provide expert advice can help clarify the steps needed to reach the solution.
HeartEngineer
Can somebody please walk me through how to solve this? I have tried numerous times but can not seem to find the right answer
You should start as usual: at point B all the tension forces add up vectorially to zero. What does that mean?
I know that the summation of forces in the x and y directions need to add up to zero, I have tried so many times I am just simply at a loss at this point
Please post what you have tried.
