Beam with two supports + spring
1 reply · 3K views · last reply
Jakob
I have beam supported in three points (one of the support is spring) .
What i know:
PR = 100kN/m
spring constant Z = 10kN/m
I have to calculate bending moments and shear forces in points A, B and Z.
Hand-drawn beam diagram: a horizontal beam with a spring support at the left end and pinned supports labelled VA and VB; a uniform downward load PR over a 4 m span, with dimensions 0.4 m, 4 m, 0.6 m and 6 m; spring constant Z and force FZ marked. PR = 100 kN/m, Z = 10 kN/m.
[/B]
ΣM = 0
ΣF = 0
Spring force : Fz=-zx
This is not enoug to solve the problem. I have two equations and three unknowns (VA, VB, and x)
[/B]
I was thinking about finding deflection of the beam in point Z however the shape of the beam between points Z and A is quite complicated. Maybe there is some simpler method and I can't see?
I will be very gratefull for help/hint with that!
  • Hand-drawn beam diagram: a horizontal beam with a spring support at the left end and pinned supports labelled VA and VB; a uniform downward load PR over a 4 m span, with dimensions 0.4 m, 4 m, 0.6 m and 6 m; spring constant Z and force FZ marked. PR = 100 kN/m, Z = 10 kN/m.
That is the right approach, but of course it is a bit more complicated here because the deflection and the force at Z depend on each other.
You will need to step through the usual procedure for figuring out the shape of the beam, but treating the force at Z as an unknown.
