Bending of members made of several materials
When dealing with non-homogeneous cross sections, bending stresses can be calculated by transforming the section into a homogeneous one using a factor 'n' based on the modulus of elasticity. The process involves finding the centroid and moment of inertia of the transformed section, then applying the bending stress formula. For shear stress calculations, the same principles apply, utilizing the formula stress = V*Q/(Ib), where Q and I must be determined for the specific cross section. The method allows for assessing the stress on fasteners like glue or rivets that join different materials. This approach effectively addresses both bending and shear stresses in composite materials.
Dell
when given a non homogeneous cross section, i know that i can find the bending(normal ) stresses by transforming the cross section into a homogeneous one by multiplying the area of one of the materials be 'n', where n=E1/E2,
then i solve normally, finding the centroid of the new cross section, finding the moment of inertia, and then simply using stress=-y*M/I, finally when calculationg the stress for the second material(the one i transformed), i multiply the answer i got by the same'n' i used.
can this method be used to calculate the shear stress somehow?? how would i find the shear stress in a non homogeneous cross section,
if stress=V*Q/(Ib) how do i calculate Q and I? can i use the same normal as in normal stress
Exactly. That is how you do determine the stress needs of whatever is fastening the two materials together, be it glue, welds or some other discrete fastener such as rivets.
