Finding h in the Fluid Dynamics Lab
In the fluid dynamics lab, students are tasked with measuring the height of fluid levels (h1 and h) before and after opening a hole, recording values every 30 seconds. The relationship between these measurements is expressed in the equation x = 2√(h(h1-h)), which needs to be rearranged to isolate h. The challenge lies in determining how to derive h from this equation and understanding the corresponding x values. A suggestion was made to find linear functions f(x) and g(h1) to facilitate this process. The discussion emphasizes the importance of correctly interpreting the relationship between the recorded values and the calculated results.
belinda
okay, so the lab that we did is called fluid dynamics. where we open a hole but before we are supposed to record h1 before the hole is open and also measure the height of the hole. h1 is higher than h. so every 30 seconds, we have to record h2, h3 ,h4 corresonding with their range, thus their x values until we reach close to h. an equation that x can also be calculated as x = 2√(h(h1-h). so we are told to rearrange the equation to deduce it to where h is either the slope or the intercept and then to find h and compare it with the recorded h. My question is how do i find h from this equation. and what is going to be the x value, is the x value the recorded value that corresponds to h recorded
x = 2√(h(h1-h).
so far, this is the equationh1=1/4h x^2-h^2/h that i got but i have no idea how to find h
Welcome to PF!
Hi belinda! Welcome to PF! :smile:
(try using the X2and X2 tags just above the Reply box :wink:)
You have x2 = 4(h1h - h2).
You need to find functions f(x) and g(h1) such that the f,g graph is linear (ie, f = Ag + B). :smile:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
