Binary System in circular orbit: Separation distance between stars
5 replies · 2K views
Thomas Smith
The binary system has a parallax of 0.07 arc seconds. This system consists of two identical stars in circular orbits.
An absorption line at a wavelength of 512nm is seen in the spectra of both stars. This line is split into two components by the orbital motion and has a maximum separation of 0.04nm, which occurs every 26 years.
What's the separation distance between both stars?
Distance to Star System from parallax d=1/p
Doppler Shift Δλ = λ - λ_0
Radical Velocity v_r=Δλ/λ_0 c
Distance is d=1/0.07 = 14.3 parsecs
The Doppler shift of one star is, Δλ = 512 - 512.04 = -0.04
So the radical of the velocity of the star is = (-0.04/512) x (3.00 x 10^5 km/s) = 23.4km/s which is the same for both stars because they have the same mass.
This is as far as I've got.
on Phys.org
jbriggs444 said:
From the information provided, can you determine the orbital period of the binary system?
Well considering the separation of 0.04nm every 26 years, I believe the full orbit period is 52 years.
jbriggs444 said:
If you make an assumption about orientation, you have tangential velocity and period...
Ah sorry, i missed out the inclination. It says the orbital plane is inclined to the plane of the sky by 90 degrees
That was the assumption I'd needed for the problem to make sense. So we are looking at the binary system, "edge on". Does that give you everything you need to finish the exercise?
