How Does Altering pH Impact ATP Synthesis in the Respiratory Chain?
In summary, making the intermembranal space more acidic would increase the concentration gradient and potentially increase ATP synthesis in the short term. However, in the long term, it could lead to denaturation of proteins, such as the cytochromes, which could affect ATP production. Extreme pH levels can denature enzymes and proteins, rendering them ineffective.
jasper10
55
What would happen to the level of ATP synthesis in the respiratory chain if you make the intermembranal space more acidic more acidic? What if it were made more basic?
ATP synthesis is triggered by chemiosmosis - the flow of H+ protons down their concentration gradient, through ATPase. ATPase uses this motion to synthesise ATP. Adding acid means adding more protons. Does this mean that ATP production will increase? Could acidic conditions damage the chain?
Is that the exact statement of the question? As posted the question makes no sense. Membranes (which are not aqueous) do not have a pH. Is the question asking what happens if you make the mitochondrial matrix more acidic/basic?
As for the question, you need to consider in what direction the H+ gradient is setup. Do protons flow from the mitochondrial matrix to the intermembrane space or vice versa? How would adding protons to each side of the mitochondrial inner membrane affect the concentration gradient?
yes: What would happen to the level of ATP synthesis in the respiratory chain if you make the intermembranal space more acidic more acidic?
Yes in respiration the protons flow from the mitochondrial matrix to the intermembranal space. So making it more acidic would increase the concentration gradient: this is only in the short term run. In the long term run, wouldn't the proteins be denatured for example the cytochromes? Why do extreme pH's denature enzymes and proteins? thx
What is the respiratory chain in biology?
The respiratory chain, also known as the electron transport chain, is a series of biochemical reactions that occur in the mitochondria of cells. It is responsible for the production of ATP, the energy currency of the cell.
How does the respiratory chain work?
The respiratory chain consists of a series of protein complexes and electron carriers that are located in the inner membrane of the mitochondria. As electrons are passed along the chain, energy is released and used to pump protons from the inner to the outer compartment of the membrane. This creates an electrochemical gradient, which is used to power the production of ATP.
What is the role of oxygen in the respiratory chain?
Oxygen is the final electron acceptor in the respiratory chain. It is necessary for the process of oxidative phosphorylation, which is the last step in ATP production. Without oxygen, the respiratory chain cannot function properly and ATP production is greatly reduced.
How does the respiratory chain relate to cellular respiration?
The respiratory chain is an essential part of cellular respiration. It is the final stage in the process of breaking down glucose to produce ATP. The first two stages of cellular respiration, glycolysis and the Krebs cycle, produce the molecules that are needed for the respiratory chain to function.
What happens if there is a problem with the respiratory chain?
If there is a problem with the respiratory chain, it can lead to a variety of health issues. These can include muscle weakness, fatigue, and neurological problems. In some cases, a malfunctioning respiratory chain can lead to mitochondrial diseases, which can have serious and even life-threatening consequences.
14K
  • Other Physics Topics
  • Beyond the Standard Models
30K
