BJT common emitter collector to emitter reverse bias confusion
The discussion clarifies the operation of an NPN transistor in a common emitter configuration, specifically addressing the biasing of the emitter-collector junction. For the transistor to operate in the active region, the emitter-base junction must be forward biased while the emitter-collector junction must be reverse biased. The base acts as an anode for both junctions, and when the collector is at a higher positive potential than the base, it effectively reverse biases the base-collector junction. This understanding resolves the initial confusion regarding the biasing conditions.
  • Understanding of NPN transistor operation
  • Knowledge of semiconductor junctions and biasing
  • Familiarity with common emitter configuration
  • Basic electronics terminology
  • Study the characteristics of NPN transistors in detail
  • Learn about the impact of biasing on transistor operation
  • Explore the differences between common emitter and common collector configurations
  • Investigate the role of voltage levels in biasing junctions
Electronics students, circuit designers, and engineers seeking to deepen their understanding of transistor biasing and operation in common emitter configurations.
learner_89
Iam sorry if it is a very basic question but iam unable to understand this
if u take a common emitter configuration of npn transistor the emitter is common to both the input and output terminals and to operate in the active region
1. the emitter to base should be forward biased i.e n and p should be forward biased this is fine,
2. also the emitter to the collector should be reverse biased that is n and n regions should be reverse biased but how can u reverse bias this.
it is very confusing could somebody clarify on this.
Thanks in advance,
In an NPN transistor, the base is an anode for two diodes and the emitter and collector are cathodes.
So, if the base is more positive than one of the cathodes, that diode will be forward biassed.
This is clearly the case with the base emitter junction.
With the base collector junction, the collector is normally at a higher positive potential than the base, so it reverse biasses this diode.
Thankyou i understood it now.
11K
  • · Replies 62 ·
11K
