Blackbody Radiation: 100K to 1000K Energy Increase
The discussion focuses on calculating the increase in radiated energy when a blackbody's temperature rises from 100K to 1000K. The correct answer is identified as a factor of 10,000, based on the Stefan-Boltzmann law, which states that power is proportional to the fourth power of temperature (P ∝ T^4). Participants express confusion over the distinction between energy and power in the context of the problem, highlighting that the question does not explicitly mention power. The relationship between temperature and energy is clarified through the equations provided, emphasizing the importance of understanding the underlying physics. Ultimately, the consensus is that the energy increase is substantial due to the fourth power relationship.
CaneAA
By what factor does the radiated energy increase when a blackbody changes temperatures from 100K to 1000K
a) 100
b) 6600
c) 1 x 10^ 4 <--- marked as the correct answer on the key.
d) 5.7 x 10^4
e) 1 x 10^6
1) f(peak) = 5.88x10^10*T
2) E = hf
By inspection, I see that if T increases by a factor of 10, the frequency will increase by a factor of 10 and so will the energy. So I'm getting that the answer is a factor of 10. I even plugged in numbers and I still get 10. I don't understand how they got that answer.
I see, thank you. But how do you know they're referring to power and not energy? They don't mention power or rate of energy radiated.
If I told you that a mass was increased, then you would assume the gravitational force on it was also increased. It's a similar idea with energy and power.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
