Block, spring, and mass problem
  • Thread starter Thread starter kiwikahuna
    Block Mass Spring
A 0.1 kg block suspended from a spring stretches an additional 4.4 cm when a 28 g stone is added, leading to calculations for frequency, period, and net force. The spring constant was calculated as 6.236 N/m, with a frequency of 1.11 Hz and a period of 0.900 seconds, indicating a half-period of 0.450 seconds for the block's motion. The net force on the stone at maximum upward displacement was initially miscalculated, as the focus should be on the stone's dynamics rather than the block's. To find the correct net force, it's essential to determine the acceleration of the block and stone together. Properly applying the equations of motion will clarify the net force acting on the stone.
kiwikahuna
A 0.1 kg block is suspended from a spring. When a small stone of mass 28 g is placed on the block, the spring stretches an additional 4.4 cm. With the stone on the block, the spring oscillates with an amplitude of 14 cm.
(a) What is the frequency of the motion?
(b) How long does the block take to travel from its lowest point to its highest point?
(c) What is the net force on the stone when it is at a point of maximum upward displacement?
I was able to solve a & b, but am having trouble with c.
First, I found the spring constant by using the info that the 28 g stretched the spring 4.4 cm.
F = k Δx or k = F / Δx = mg / Δx = 0.028 * 9.8 / 0.044 = 6.236 N/m
Then I found the angular freq of the motion:
ω = ( k / m )1/2 = ( 6.236 / 0.128 )1/2 = 6.98 rad/s
and then the freq is
f = ω / 2π = 6.98 / 2 π = 1.11 Hz
The period of the motion is
T = 1/f = 1 / 1.11 Hz = 0.900 sec so the time to get just from bottom to top is half this or
0.450 sec
Finally, I thought that the net force on the block at the top is
F = kA = 6.236 N/m * 0.14 m = 0.873 Newtons but this answer isn't right. What did I do wrong though?
Please help! thank you!
I think your spring constant is wrong. With only the 0.1 kg block on the spring the spring stretches by an amount
<br /> \Delta x = \frac{-m_{1} g}{k}<br />
where m_{1} is the mass of the block. When the stone is placed on the block the spring stretches an additional 4.4 cm. This would give
<br /> 0.044(meters) + \Delta x = \frac{-(m_{1}+m_{2}) g}{k}<br />
Where m_{2} is the mass of the stone. I would use these two equations to solve for k.
When both masses are on the spring, this would lead to the following equation of motion:
<br /> (m_{1}+m_{2}) \ddot{x} = -k x - (m_{1}+m_{2}) g<br />
Where x is the displacement from equilibrium when there is zero mass on the spring.
Your spring constant is just fine. The question asks for the net force on the stone, not on the block. It may help to find the acceleration of the block (and hence the stone) at the point.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
