Blocks, Friction Forces and Acceleration
A block weighing 50.0 N is subjected to a horizontal force of 25.0 N, with static and kinetic friction coefficients of 0.510 and 0.350, respectively. The static friction force is calculated to be 25.5 N, which exceeds the applied force, indicating the block will move. Once in motion, the kinetic friction force is determined to be 17.5 N. To find the block's acceleration, the net force is calculated by subtracting the kinetic friction from the applied force. The discussion emphasizes using Newton's second law to analyze the forces acting on the block.
sunnyorange
I am having trouble with this problem:
A block whose weight is 50.0N rests on a horizontal table. A horizontal force of 25.0 N is applied to the block. The coefficients of static and kidnetic friction are 0.510 and 0.350 respectively. Will the Block move under the influence of the force and if so, what will be the block's acceleration?
What I have so far:
1. Fs=mu sN
=0.510*50
=25.5 N
25.5 N>25.0 N, therefore the block will move under the influence of the force.
2. Finding acceleration
I know I have to find the net force then use that in the second law equation. How do I do that.
I have kinetic force=17.5, mass=50/9.8=5.10 kg.
Please help!:cry:
You might want to look at this again. Which one was the force due to static friction?
You are correct so far.
Think Newton's second law: the pulling force stays the same, but now instead of static friction, there is kinetic friction. What's the net force?
Would the net force be: applied horizontal force-kinetic friction force?
yes, that's correct (there are two other forces in the vertical direction, but Normal force and weight will balance each other in *this* situation).
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
