Boeing How Safe is the Boeing 737 Max's MCAS System?
The discussion centers on concerns regarding the Boeing 737 Max's Maneuvering Characteristics Augmentation System (MCAS) and its potential flaws, particularly its ability to execute a nose-down maneuver at any altitude. Participants express confusion over the system's operation, noting that MCAS is designed to assist pilots by adjusting trim rather than overriding their control. There are significant concerns about the system's reliance on angle of attack sensors, with suggestions that a third sensor could improve fault detection. The idea of implementing a minimum altitude threshold for MCAS activation is debated, with some arguing it could prevent dangerous situations during critical phases of flight. Overall, the conversation highlights the need for better safety measures and clearer pilot control in automated systems.
  • #251
russ_watters said:
You really think "harder" and "physically impossible" are the same thing? The difference is that with "harder" the plane falls out of the sky and with "physically impossible" it doesn't. That's a big difference!
I'm referring to this statement you made: "So again, the difference between "trying to get the nose down" and "helping you avoid letting the nose rise too high" is not very critical."
  • #252
cyboman said:
The post you just responded to of mine I think pretty clearly explains that. To summarize it quickly: Your perspective implies MCAS has no pitch authority, which I don't agree with.
I get that that's your point, but that doesn't explain why you think it's important. What useful thing does it tell us about the crashes?
Looking back at some of the posts I missed over the weekend, evidently @PeterDonis had a virtually identical discussion with you. At this point, since it seems like just semantics with no value - nothing to tell us about the crashes, I don't see a need to continue it.
  • #253
Like I said, "It could be seen as unimportant I suppose. I guess the importance of the point is it stems from seeing the system as not ultimately having a direct effect on attitude. It seems to suggest MCAS doesn't have any pitch authority."
If you're asking why I think it's important to see MCAS that way, I guess the answer would be, because to see it in a different way wouldn't be accurate and would serve to inaccurately represent how MCAS operates.
I agree there's no point discussing it further, I'm comfortable with the points I made before this, I was just originally replying to your post, it wasn't my intent to revive the disagreement. It was already established you and Peter saw it the same way. I just thought it respectful to respond to your post since you took the time to write it.
I have to add when Boeing states: "...a limit of 0.6 degrees, out of a physical maximum of just less than 5 degrees of nose-down movement." It seems odd to still see the MCAS as not moving the nose down or effecting pitch.
  • #254
russ_watters said:
I'm not sure if the action of the trim in the 737 is direct or reversed
It seems pretty clear to me from what I've seen that the trim function on the 737 changes the angle of the entire horizontal stabilizer, which changes its default angle of attack ("default" meaning "if the elevators are in the neutral position") and therefore the default amount of lift force it exerts at the tail end of the plane. So it would be a different method of working from trim tabs.
Likes cyboman
  • #255
Would it be erroneous to think of trim tabs as basically small rudders on the elevators? So in the Cessna example, the Cessna elevators would be more akin to the stab on the 737, and the Cessna trim tabs more akin to the 737's elevators?
EDIT: I guess that's imperfect since looking at the Cessna it still has a horizontal stabilizer too, which doesn't rotate.
  • #256
I do think it's direct acting, but I can envision a way it might not be: if adjusting the trim control moved both the stabilizer and the elevator, in opposite directions. Or if the trim adjustment just moves the stabilizer and the pilot responds by moving the elevator.
The advantage of moving both would be that the control column wouldn't need to move in response to a trim change. The pilot would still move it unconsciously, and then move it back, but back to the same position. Otherwise, every time you changed the trim, the neutral position of the yoke would be in a different place. Maybe that doesn't matter much because the neutral position isn't marked anywhere, but I don't know.
It's also worth noting that trim and feel for the pilots can be whatever the designers want; the control surfaces are actually moved hydraulically and the feel for the pilots doesn't need to match what the hydraulic cylinders are applying.
  • #257
It's a similar idea. What creates the force against the control column is the elevator not being aligned with the stabilizer - it's the wind pushing it back down. The all-moving trim aligns the stabilizer and elevator by changing the stabilizer angle whereas the trim tab changes the force directly, by giving the elevator its own lift.
Likes cyboman
  • #258
AFAIK the 737 already does considerable artificial feel adjustment.
Likes russ_watters and cyboman
  • #259
Erm, those are so the pilot doesn't have to think about the aerodynamics and mechanics of the stabilizer when he's manipulating the trim. Obviously, it doesn't lower then nose only by 5 degrees either. Similarly, in my Cessna, it doesn't say down trim to raise the nose - that would be confusing!
  • #260
Yes. From a link I posted earlier:
Incidentally, it looks like we're describing "up" and "down" incorrectly for the stabilizer? It says "Stab LE Down = airplane nose up" Not sure what "LE" stands for...
This is one of several such graphs. One was a simple speed vs angle. Honestly, these are pretty complicated and I haven't put forth the effort to think them through.
Either way, not that important: trim adjustment is made clear to the pilot in terms of what you want the nose to do, not the direction the control surface moves (per @cyboman's last post).
[edit] I believe the above is just telling us where the neutral position is, not what the automated trim adjustment is. Here's an example of automated trim adjustment:
Likes cyboman
  • #261
I would assume "leading edge".
Likes russ_watters
  • #262
I think what it might be is when it says "Stab LE Down = airplane nose up". It's saying when the stab is rotated downward or forward, which is "down" from the horizontal, it results in the nose up moment and vise versa. We've been referring to the stab adding nose down trim. I don't think we were saying the stabilizer moves down for nose down trim.
EDIT: *..which is "down" from the horizontal looking at the LE / leading edge (thx @PeterDonis)
Like it says here: "MCAS moves the horizontal stab trim upward..."
I was going to ask you to explain the graph actually, because I find it hard to understand.
  • #263
OK, this might be a little silly and over simplifying but I'm going to throw it out there.
If they just increased size of the stab and thereby it's trim changes would be magnified, could they perhaps just of changed the existing automated trim systems like auto speed trim and other flight software appropriately, they could of then avoided the MCAS "patch"? And eliminate the complication of over-engineering by adding a system like MCAS which introduces a host of new variables and failure modes?
EDIT: I guess it's not that silly because I've read elsewhere which I posted, that people have suggested they should of just redesigned the stab. I suppose I think I'm oversimplifying by "making it bigger" but maybe that's generally speaking, accurate?
  • #264
Me Tarzangineer, me think bigger engine, and bigger up pushing, me think need bigger back wing.
  • #265
Actually on this line of thought, even if they didn't change the stab. Why couldn't they just adjust the existing auto trim and force feedback systems to accomplish basically what MCAS does? Why is an additional system or "subroutine" or whatever needed? Sometimes it's qualified as an additional stall prevention system to deal with the engines. But why not just reconfigure the existing stall prevention systems?
  • #266
I think this largely, as is suggested in the articles, boils down to a cost assessment. Down to money. So redesigning the stab is expensive and then the clients need to worry about new parts for that and lengthy re-certification for changes to the airframe. Redesigning the existing flight systems like autotrim and elevator feel control, also requires re-certification and is also expensive. Adding a new control or augmentation system maybe falls into a different path of certification and has the lowest cost. BUT, is the FAA not considering how new systems like MCAS effects other systems and therefore their previous certifications for them is invalid? It almost seems like they may be viewing all these systems as disparate, but they actually all interact with each other, and changes to one effects all other systems and their expected performance.
  • #267
PeterDonis said:
I'm not sure what Boeing's equivalent of Direct Law ...
The Airbus has several "Laws" that can be selected for control of the plane. Most fundamentally are Direct Law and Mechanical Law. They are very specific to Airbus - which normally takes pilot control input as an indication of the pilot's intention - and then moves the control surfaces with those intentions in "mind".
For other aircraft, "Direct Law" is approximately equivalent to normal manual flying.
Likes cyboman
  • #268
PeterDonis said:
Not pitching down just means the airplane crashes tail first.
No. If you want to crash tail first, you need to put the center of gravity (CoG) well aft of the center of lift or execute some really wild maneuvers.
All normal aircraft are designed so that when the wings stall, the nose drops. Holding the yoke back will allow a stall to persist.
The aerobatic maneuver for inducing the plane to fly backwards is called a tail slide. I have piloted two different aerobatic aircraft (Citabria and Decathalon), but neither of them was certified for tail slides.
Likes cyboman and berkeman
  • #269
Andrew Mason said:
I don't understand is how stall detection can be based only on angle of attack. A low speed and low angle of attack can still result in a stall. A high speed steep climb can be perfectly ok.
AM
There is only one cause for a stall - high AoA. Each aircraft has a "maneuvering speed", which is the fastest that the plane can go without being subject to damage by aggressive pilot inputs (primarily pitch up/down). Manuevering speed is not "slow" - though it is less than a normal operating speed. If you pull the nose of the plane up in straight and level flight at maneuvering speed, you will enter a stall. If you hold that stall for a moment and then slam on rudder (left or right), you will fully stall one wing (the one turned back) while generating maximum lift from the other. That's called a snap roll.
At very low speed (below the minimum controllable airspeed) with low angle of attack means that you are not generating enough lift to offset your weight - so you will be accelerating downwards. Perhaps you are following a parabolic trajectory.
Likes cyboman
  • #270
russ_watters said:
It is probably worth considering that for the plane I'm flying and any plane with trim tabs, if moving the tab were directly affecting the plane's attitude without a change in elevator position, the trim tab would move the nose in the wrong direction. The trim tab is there to apply aerodynamic force to the elevator. When the tab tilts up, it pushes the elevator down. If the elevator didn't move down as soon as the tab tilted up, the nose of the plane would rise instead of dropping.
That said, I'm not sure if the action of the trim in the 737 is direct or reversed, but either way it doesn't matter because it instantly changes the force and the elevator and yoke moves in response.
The action of the 737 trim is dramatically direct.
There may be some confusion here because the "trim" on a jumbo jet operates differently than the trim on most small planes. In the case of most small planes, the pitch force adjustment is not controlled by a surface as large as the horizontal stabilizer. In fact, for most sail planes - trim is controlled by the positioning a tie point of a long spring.
  • #271
PeterDonis said:
This says "Using electric pitch trim will only pause MCAS, to deactivate it you need to switch off the STAB TRIM SUTOUT switches." This seems to indicate that the cutout switch the pilot comment we were discussing referred to does disable MCAS.
Right.
This is part of the problem. If you use the electric pitch trim - the MCAS (which also uses the electric pitch trim) will back off - but only for a short time (less than half a minute). Then it will turn the trim back to what it thinks is correct.
So you need to use the electric trim to put it where you want - then quickly kill it with cutout switch.
If you use the cutout, you're stuck with the manual wheel - which may operate too slowly to save the aircraft. Basically, this is a device in the cockpit that directly turns the jack screw that positions the horizontal stabilizer. So it take many turns to get just a little stabilizer motion.
The horizontal stabilizer are those small "wings" in the back. The elevators are along the trailing edge of the stabilizers. When the stabilizers are out of position, much more elevators deflection is required - and this mean more pitch up or down force by the pilot.
Likes cyboman
  • #272
Here is a pprune post from "Aloha_KSA" that goes a long way to understanding the problem presented to the pilots:
https://www.pprune.org/rumours-news/619272-ethiopian-airliner-down-africa-102.html#post10423122
As a long-time 737 driver I'll just chime-in a few points. Regarding the trim wheel ability to move the stab at high speed from full deflection: I seriously doubt that there would ever be too much force on the elevator that the trim wheel could not move it. There is a lot of leverage in the jack screw, and the turns of the trim wheel make very minute changes to the angle of the stab.
But know that moving from full deflection to neutral would take a painfully long time. On the -200 we used to wind the trim full fore and aft as part of the preflight checks. (We stopped doing that on the NG.) . Using the motor-driven trim this took about a minute to go full forward, full aft, then back to about 4 units. It is not physically possible to wind the trim wheel that fast for that long manually, especially when your aircraft is lurching about like a rodeo bull. Also note that it doesn't take much movement to change the aircraft's attitude significantly, and the aircraft is very controllable using manual trim. Back in the cargo days I once did a 20 minute flight using only the rudder and stab trim and manual power (on the -200) from after flaps up to 10000' on descent. That's right - I didn't touch the yoke, autopilot-off from climb-out to descent. It was very controllable and stable. (That was a good training exercise, too.)
My First Point: If we don't catch this mis-trim early, un-doing it manually will take a very long time and maybe more time than is available when your aircraft is only 1000' AGL. AND to use the trim wheel for more than small changes, one has to fold the handle out. A handle that has injured many a knee in simulator sessions because combined with the trim motor's speedy rotation of the wheel, it can leave one with a permanent limp.
Second: For all the arm-chair Monday morning QB's who are saying: "Oh, they should have recognized it immediately and disconnected the trim:"
(1) Just after takeoff there is a lot going on with trim, power, configuration changes, and as noted above, the darn speed trim is always moving that trim wheel in seemingly random directions to the point that experienced NG pilots would treat its movement as background noise and normal ops. Movement of the trim wheel in awkward amounts and directions would not immediately trigger a memory item response of disconnecting the servos. No way.
(2) The pilots could very reasonably not have noticed the stab trim movement. Movement of the stab trim on the 737 is indicated by very loud clacking as the wheel rotates. On the -200 it was almost shockingly loud. On the NG, much less so. HOWEVER, the 737 cockpit is NOISY. It's one reason I am happy to not be flying it any more. The ergonomics are ridiculous. Especially at high speeds at low altitudes. With the wind noise, they may not have heard the trim wheel moving. The only other way to know it was moving would be yoke feel and to actually look at the trim setting on the center pedestal, which requires looking down and away from the windows and the instruments in a 'leans'-inducing head move. On the 717, for example, Ms. Douglas chimes in with an audible "Stablizer Motion" warning. There is no such indication on the 737.
(3) The fact that they were at high power and high speed tells me the stick shaker was activated. With that massive vibrator between your legs, alternating blue sky and brown out the window, your eye balls bouncing up and down in their sockets as the plane lurches up and down in positive and negative G's, it would have been a miracle if one of the pilots calmly reached down, flicked off the stab servo cutout switches, folded out the trim handle, and started grinding the wheel in the direction of normalcy. These pilots said over the radio that they had "unreliable airspeed". So they did not even know which instruments to rest their eyes on for reliable info. Their eyes were all over the cockpit looking for reliable info, the plane is all over the place like a wild boar in a blanket not behaving in any rational way. And the flying pilot may have been using the tiny standby IFDS for airspeed and attitude. Ouch.
Finally, runaway stab trim is a very, very rare occurence up until now. We trained it about once every other year in the sim because it is so rare. And when we did it was obvious. The nose was getting steadily heavier or steadily lighter with continuous movement of the trim wheel. That is a VERY different scenario than what these pilots faced.
We also trained for jammed stabilizer, the remedy for which is overcoming it with force. The information they were faced with could very reasonably have been interpreted that way, too.
An URGENT AD from the FAA/ Boeing after Lion Air would have helped get it back to the front of the pilot's minds for sure. Extra training by the airline or an urgent pilot memo would have helped. Maybe one was issued, we don't know yet.
A better question might be: given this nose down attitude, high speed, and fully nose down or almost fully nose down stab, how much altitude would they have had to have to be able to recover. I'm thinking at least 10000 feet to recognize the problem, disconnect the switches, fold out the handle and start frantically winding the stab back to normalcy while the flying pilot tries to gain control via the elevator. It's entirely possible that this scenario, if not recognized early on, is unrecoverable at any altitude.
Likes artis, Klystron, russ_watters and 1 other person
  • #273
Regarding the attitude indicator:
cyboman said:
Yes, I imagine that is a very mission critical instrument to a pilot. Not many failure modes for that sucker I imagine.
The "artificial horizon", that black and blue ball in the middle of the control panel is as important as its real estate implies. It can fail when the power system (electric or vacuum) that its depends on fails - which is why there are often one of each in the cockpit.
https://www.boldmethod.com/learn-to...your-only-attitude-indicator-in-imc-now-what/
Other instruments can be used to compensate when there is no functional attitude indicator - and these procedures are practiced as part of instrument pilot training.
Likes russ_watters
  • #274
Does this plane have only one AOA sensor? If so, that is a problem right there. Everything that is flight critical should have redundancy.
(I am a pilot.)
  • #275
(I am a pilot.)
According to a Boeing site, it has access to both AoA sensors, but only uses one at a time. Alternating from one to the other from flight to flight.
http://www.b737.org.uk/mcas.htm
  • #276
(I am a pilot.)
It has two, but MCAS only reads one. I've read most airliners use 3 and the really big ones use 6. I think it's fairly well established that there is some big problems with the MCAS, not just the sensor. In a nutshell being, how much the system can adjust the stab (see the latest Seattle times article linked in the thread), how often it can do that, which appears to be infinitely as it resets and can max out the nose down trim of the stab. Add poor HCI with annunciations and instrumentation to communicate what's going on. It get's worse and worse. Much is covered in this thread.
  • #277
  • #278
Interesting, I sort of want one now. I thought they were like a compass and relatively simple mechanically. That's why I thought they wouldn't have many failure modes. Then I wiki'd them and looked what they cost on ebay. Not soo much...
I looks like it failed in this case: https://en.wikipedia.org/wiki/Aeroflot_Flight_2415
  • #279
I had a question before which is sort of related. I still don't understand it completely: If MCAS is meant to be active in scenarios of high AoA and pitch up conditions. Would it ever be active when the plane has a negative pitch attitude. It was suggested this could occur during a dive when the pilot is pitching up to pull out. But it doesn't seem likely adding nose down trim in that scenario would be beneficial so wouldn't it be improbable MCAS would be active then?
I guess it seems counter intuitive imagining MCAS operating in negative pitch attitude scenarios since it's often described as a stall prevention system.
  • #280
High AoA, yes. Pitch up, not necessarily. As @russ_watters reminded me in post #238, AoA is not the same as pitch attitude. AoA is the angle between the wing and the relative wind; if the plane is descending fast enough, AoA can be high even if the nose is pitched down.
  • #281
The specific problem that MCAS was meant to solve was that without it, pilots that were accustom to the handling of the 737 could unintentionally put the MAX into a stall - for example, during steep banks. So what MCAS does is monitor the aerodynamic environment of the plane - not its orientation, not its proximity to the ground - just its interface to the air. If it determines that the pilot might be induced to pull harder than he should (that he would on a 737), it will reposition the horizontal stabilizer to create the familiar 737 environment.
For MCAS, "useful" doesn't mean less effort for the pilot, it means creating the same amount of effort that the pilot expects.
So, let's say that they plane has already stalled - and the nose has dropped as it will even without pitch input from the pilot. What the pilot needs to do now is to push the nose down even more - to pick up air speed. Then the pilot will need to begin a fairly high-G pull up - enough to avoid excessive airspeed and the ground, but not enough to break the plane or injure the passengers. During these maneuvers, all of which are done with the plane pitched towards Earth, the pilot will be operating the yoke mostly by feel. His eyes will be on other things. So it's important that the plane respond based on this expected feel.
Likes jim hardy and russ_watters
  • #282
Right, yes I remember this. I believe I got that wording from the Boeing flight man has MCAS described that way, but I think it's meaning is high AoA and pitch up conditions, meaning the plane is "wanting" to pitch up or the pilot is pulling up. So it's a condition not an attitude. Confusing wording.
  • #283
Thanks, that example helps.
  • #284
According to this page:
To summarise; MCAS will trim the Stabilizer down for 10 seconds (2.5 deg nose down) and pause for 5 seconds and repeat if the conditions (high angle of attack, flaps up and autopilot disengaged) continue to be met. Using electric pitch trim will only pause MCAS, to deactivate it you need to switch off the STAB TRIM [CUTOUT} switches.
So, it appears that only AoA, flaps, and autopilot states are important.
  • #285
Other sources linked to in this thread have indicated that the pitch up moment due to the new engines depends on airspeed as well as AoA, so one would expect that the MCAS algorithm would also have airspeed as an input. But I have not seen any source actually say that.
  • #286
The word "pitch" is a noun and a verb and yes, "pitch up" and "up pitch [attitude]" mean very different things. One is a position and the other a motion.
Likes Klystron
  • #287
Actually that's exactly where I got it from. If you look at the image right above where you're quoting, which is a page from the flight manual, the last paragraph under the MCAS heading says:
"The MCAS only operates at extreme high speed pitch up conditions that are outside the normal operating envelope."
But as I've suggested, perhaps "conditions" is not saying it's only active with actual positive pitch attitude, but instead implying when the plane is being maneuvered to pitch the plane upward from it's current attitude. That is, it won't be active when the pilot is pushing forward on the yoke. Again the language is a bit confusing to me.
  • #288
Right, so then in the manual it's referring to the motion right not position or attitude? "...pitch up conditions..."
  • #289
The grammar of each sentence will tell you. [edit] The noun version matters to the pilot because he can't see his aoa, but the flight control computer probably mostly cares about the verb.
  • #290
It a page from the training manual:
In this case, "pitch up condition" means that the pilot is pulling on the yoke to pitch the plane further up. For example, he may be attempting to pull out of a dive.
A pitch up that is outside normal operating envelope is one that would either threaten a stall or threaten aerodynamic damage to the plane.
When the word "envelope" is used, it is talking about the flight limitations of the airplane - that are independent of its attitude.
That is probably why it it is also looking at the bank angle. Though that is not as well advertised, it is shown in the graphic as "steeply turning".
When a plane is making a turn at more than the standard turn rate, an "accelerated stall" is possible.
  • #291
Ahh right, that's what I thought.
  • #292
@.Scott Would you happen to know the maximum stab nose down trim angle on the Max? I was wondering if it's possible to calculate the maximum nose down movement the system could cause (this is obviously due to other moments too as it applies to final pitch attitude). But it could work to show it could actually be impossible to recover the plane with such nose down movement. I asked here in relation to data in the Seattle times article:
cyboman said:
So the actual stab limit of 2.5 degrees would give a physical maximum of 20.8 degrees of nose down movement (assuming they are directly proportional)? That seems like a pretty insane amount of potential pitch attitude change for a system that's supposed to be so invisible it's not worth mentioning. And, it can keep resetting and essentially max out the nose down trim of the stab. Is that origin of the name Max? j/j
I wonder what the maximum nose down trim angle of the stab is. I looked but couldn't find it. Thought it would be here: http://www.b737.org.uk/techspecsdetailed.htm but couldn't find it. One interesting thing you can see is that the stab in the Max is unchanged from the previous NG model. Maybe a redesign of the stab would of been worth the cost, as opposed to the MCAS software which mysteriously changes the control surface behind the scenes.
  • #293
It would be a function of both the stabilizer angle and the airspeed.
Here is the only source I see right now (for the Lion crash) - I will look harder later:
https://oppositelock.kinja.com/lion-air-737-max-8-crash-100-pounds-of-yoke-force-21-1833371123
The system would also pivot the stabilizer that much [2.5 degrees] repeatedly as long as data inputs indicated the aircraft was about to stall, regardless of the pilots’ strenuous efforts to overpower the system. In the October Lion Air crash, which killed 189 people, the flight data recorder counted the captain countering the system 21 times with the first officer taking over for [a] few tries before the captain’s final futile efforts to arrest a 500-MPH dive. The data indicated the nose-down yoke forces peaked at a little more than 100 pounds.
Even if it were only 30 pounds, that would be a lot to hold steady - not letting it go harder or softer.
Under normal conditions (autopilot excepted), you want to be able to control the plane with just your finger tips. So you would trim it up with that objective.
Likes russ_watters
  • #294
https://oppositelock.kinja.com/lion-air-737-max-8-crash-100-pounds-of-yoke-force-21-1833371123Even if it were only 30 pounds, that would be a lot to hold steady - not letting it go harder or softer.
Interesting thanks.
  • #295
I'm interested in the sort of instrumentation or feedback that exists that is communicating the status of the trim and it's setting / status and the autonomous systems interacting with it. Is the only feedback to the pilot of current trim settings the actual trim wheel?
  • #296
In small planes, the only trim feedback you get is difficult handling when it is out of trim.
From Aloha_KSA's description, the 737MAX also provides a noise and the sight of the trim wheel spinning when the trim is changing - both are easy to miss or ignore. Also according to KSA, there is a direct indication on the center pedestal.
So, if you are completely prepared for the malfunction, you could handle it. In fact, there is an interesting story about the flight before the fateful Lion flight. The failure occurred on that flight as well - and the crew did not catch it - but an off duty pilot sitting in the jump seat (which has a good view of the center pedestal) did catch it and gave instructions to the pilots on how to handle it.
https://www.bloomberg.com/news/arti...in-cockpit-saved-a-737-max-that-later-crashed
The procedure would be: trim back using the electric system - which will temporarily cutout MCAS and then immediately flip the STAB cutout switch.
If you have that exact sequence in mind and you recognize the problem before it develops into a roller coaster ride, it is simple.
But if it's been a year or two since you tried that in a simulator, you may remember that the issue might be MCAS and that it can be stopped with the cutout switch - so you use that switch. But now you would need to unwind the trim manually - which could take minutes.
Or you might at first think that it was stuck trim - and so you brace yourself for a lot of exertion. Only to discover in time that the trim is far from stuck and is actually getting worse and worse.
Likes russ_watters
  • #297
I found quote from another pilot that describes the value of the MCAS.
This is from retired 737 pilot "gums", at this link:
https://www.pprune.org/rumours-news/619494-mcas-altitude-v-attitude.html#post10419880
I can tellya that having the stick/wheel feel get light as you approach a stall AoA is not good. And then, if you pull back just a tad longer the nose continues to rise all by itself.
As a pilot myself, I want the plane to fight me at least a bit before going into a stall. This pilot is suggesting that the MAX without the MCAS doesn't do that at all. It just pivots up freely - eventually pitching into the stall all on its own.
What makes this important is that pilots shouldn't just turn this system off - and Boeing can't suggest that as a solution. MCAS isn't just nice for making the 737-MAX feel like a 737-NG, it is a critical safety component.
It is also worth talking about stalls. In a small plane, a full stall followed by a prompt recovery will loose you about 100 feet of altitude. A little delay and that could easily be 300 feet. But jumbo jets move fast and pivots slowly. From what I've read, recovering within 1000 feet is really excellent - and depending on the circumstances, a loss of 10,000 feet is not unreasonable. During the stall, the plane pitches down dramatically (especially as viewed from the cockpit) and the airspeed varies a lot. There is usually at least a little roll moment, and in some cases the plane can roll dramatically. Certainly, in a passenger plane, this is a maneuver to be avoided.
Likes cyboman and russ_watters
  • #298
Before computer control systems, a parallel to the current issue existed on the Boeing 727 that was discovered in flight testing prior to the release of the aircraft. The issue was that as the elevators passed through the neutral horizontal position from down to up there was sudden reduction the amount of stick force resistance that could result in the pilot pitching the plane upward toward a stall attitude. The solution used for that problem was to train pilots to anticipate the force change plus the addition of a rod of depleted U238 extending from the back inside edge of each elevator section to provide rotational inertia and give the pilot time to react to the force change.
A test pilot I had an opportunity to visit with during that time made the comment "you would be surprised how much the operating stability of an aircraft is a result of weights and springs".
Likes Klystron and russ_watters
  • #299
What I'm hearing from the pilot's perspective makes them sound somewhat isolated from the design choices, and even the design information. That doesn't seem like a good thing, we'd like to imagine the people who have to fly the plane having a lot of input into its design and certainly complete information about its design. But it sounds more like something that engineers foisted onto the pilots, framed as being for their own good, without necessarily really telling them why and how to deal with it. Is it possible that this is due to a sense that certain aspects of the MAX needed to be concealed from the pilots to mitigate objections?
The reason I ask is because If I were an engineer being tugged in several different directions in my design choices, on the one hand wanting to make a plane that pilots like to fly while on the other hand meeting various profit-related specs, I might find myself tempted to conceal from both sides of those conflicting interests some of the tradeoffs going on. Would I hesitate to tell the executives who see the corporate bottom line that the plane could fly cheaper if I just made it harder on the pilots? Would I hesitate to tell the pilots that the plane could be made easier to fly but it would cost more? If I'm tempted to conceal that kind of information, it could lead me to design systems to help compensate for the tradeoffs in ways that I am not fully forthcoming about. Could this dynamic be playing a role in the design of the MAX and the MCAS? If so, it might explain why some pilots are saying things like "why isn't this in the manual?"
  • #300
It sounds to me like stalling is such a fundamentally dangerous scenario (especially on jumbo jets as you point out) that preventing it shouldn't be "patched" with a system like MCAS that is rather violently changing pitch forces. As was suggested by a pilot on CBC, it seems they've pushed the airframe of the 737 to it's "max" and crossed a safety threshold.
