Brachistochrone curve - Gravity and other influences
ehrenfest
http://content.answers.com/main/content/wp/en/d/d4/Brachistochrone.png
Go to the link and look at this brachistochrone curve. The brachistochrone problem is supposed to find the fastest path between to points for an object under only the influence of gravity, correct?
Then how does the problem even have a solution when the coordinates are at the same height. How can the the particle swoop back up under only the influence of gravity?
There is nothing wrong if they are at the same height. There are no damping forces like friction or air resistance. It's simply the energy law, it comes to the same height and then swoop back, like pendulum.
So, it is always assumed that the particle is attached to wire or has some sort of constraint? Is the constraint always the same?
brachistochrone is a constraint. You want to calculate what shape should constraint have that time of traveling will be minimal. It doesn't matter what type of constraint is it, it's just a mathematical problem. It is also important that there are no damping forces, which is of course just ideal case.
I see, and the constraint is almost always in the form of a normal force, such as in the classic example where they are at the same height, right?
yes, for the fastest path the constraint (brachistochrone) is in the plane parallel to force. But also you have for example the skier on the slope, the shortest path is still brachistochrone, only that now it lies in the plane of the slope.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
