Are Brown Dwarfs Part of the Main Sequence on the H-R Diagram?
  • Thread starter Thread starter ZedCar
    Diagram
Brown dwarfs are not classified as main sequence stars because they do not undergo hydrogen fusion. They are located on the lower right-hand tail of the H-R diagram, but they should be considered separate from the main sequence, similar to white dwarfs. While they can fuse deuterium under certain conditions, their inability to sustain hydrogen fusion distinguishes them from main sequence stars. The existence of spectral classes L and T for brown dwarfs indicates their placement on the H-R diagram, but they remain fundamentally different from main sequence stars. Thus, when sketching the H-R diagram, brown dwarfs should be noted in the lower right corner but recognized as a distinct category.
ZedCar
Do Brown Dwarfs appear on the lower right hand "tail" of the main sequence of the H-R diagram?
Or are they separate from the main sequence?
The location here:
https://en.wikipedia.org/w/index.php?title=File:HR-diag-instability-strip.svg&page=1
appeared to show them in that location, but I wasn't sure if they are actually separate from the main sequence as the diagram isn't that clear on their location.
Thank you.
Astronomy news on Phys.org
Brown dwarfs are not main sequence stars, as they never perform hydrogen fusion, but they appear on your link at the bottom right. I don't know how accurate that particular graph is.
Thanks Drakkith.
So if I was drawing a sketch of the H-R diagram, and labelling the position of the brown dwarfs, would I just point out that they are on the lower right-hand tail of the main sequence.
Or should they be indicated as being completely separate from the main sequence in the way that white dwarfs are?
If you are going to plot them, you have to plot them according to the parameters of the graph. This necessarily puts them at the lower right I believe.
A couple extra spectral classes past M were invented for brown dwarfs - L and T, so they technically are on the HR diagram, but, not considered main sequence. They can fuse deuterium if they can achieve a core temperature of about 1 million degrees. The ones too small to fuse deuterium may as well be called orphan planets.
Brown dwarfs, as previously stated, are not on the main sequence. They are small and relatively cool and fall in the lower right hand corner of the HR diagram.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
