7.0 g bullet embedded in 3.5 kg pendulum bob with 8.0 cm rise
3 replies · 10K views
lettertwelve
bullet and pendulum bob...initial speed...help! momentum.
An 7.0 g bullet is fired into a 3.5 kg pendulum bob initially at rest and becomes embedded in it. If the pendulum rises a vertical distance of 8.0 cm, calculate the initial speed of the bullet.
________m/s
well there's many ways to do it, but here's one way:
v=sqrt((1+M/m)*2gh)
i tried it another way too, and got the same answer that i did with the above equation
so first, 7g bullet = .007kg bullet and height of 8cm = .08m
ok so then v=sqrt((1+3.5/.007)*2*9.8*.08) = ~28.03 m/s
now, i tried this TWO WAYS and got the same answer.
but webassign says it's wrong.
why?
The velocity of the pendulum and the bullet is given by:
[tex]v=\sqrt{2gh}[/tex]
The mass shouldn't enter into that part. Once v is known one can use the conservation of momentum to find the bullets initial speed.
EDIT: I see what you've done to include the mass. The problem is the mass part should be outside the square root.
which mass are you talking about?
The (1+M/m) term.
