Analyzing Emitter Follower Circuit Data: Is the Transistor Burned Out?
In summary, the conversation is about working on an emitter follower circuit and trying to troubleshoot an issue with a burnt out transistor. The circuit had a 100kΩ resistor between the Vin site and the transistor and a 100kΩ resistor for RE. The conversation includes suggestions to check the transistor and its bias, as well as recommendations for adjusting the resistor values. There is also a discussion about measuring correct voltages with a cheap multimeter, and the practicality of using low currents for a demo of an emitter follower. Additionally, the conversation mentions working on guitar electronics that require high impedance and low current designs.
cep
51
Hi all,
I was working with an emitter follower circuit similar to this one: http://upload.wikimedia.org/wikipedia/commons/b/b8/NPN_emitter_follower.svg , the only difference being that in my circuit, there is a 100kΩ resistor between the Vin site and the transistor. RE is also 100kΩ. I measured ΔV across both resistors, and now that I am looking at my results, I suspect the transistor is burned out.
My data is attached, where VI is the voltage drop across the resistor next to Vin (not pictured), and VO is the voltage drop across the resistor past the collector. Since the voltage drop across RE is constant at all values of Vin, its current is also constant.
Am I correct in thinking this transistor was non-functional?
Thanks!
I think so. The voltage at the base is stuck at 11.xx volt.
That 100 K in the emitter is too high.
Try 1000 ohms.
You have biased it wrong. Your results show its in cutoff region. Bias it properly.
I don't think it is biased wrong. There is no bias, the input is the bias and the table show all the voltages from 0 to 11V. This is only an emitter follower. I think is the transistor burnt. Assume it is NPN, the base stuck at about 11V.
I don't know about the resistor on collector. I assume VO is voltage across the emitter resistor and is always on 11 volts of so. Everything is stuck close to Vcc. The transistor is shorted.
Make sure there is no solder splash, make sure the transistor is solder in correctly, make sure it is NPN. Double check everything. I never seen a bad transistor out of the gate yet. You have to burn it.
100K at the input is a little high and is not a good practice, but it is not going to give the result in the table. NPN draw current from the base, if anything if you put 5V at the input, the base voltage is going to be a little lower because the base draw current, not stuck at 11V. Actually 100K input is not the end of the world. The emitter resistor is 100K, so the max emitter current is 110uA. At this current, a lot of transistor has beta of over 100, so the base current is going to be less than 2 uA therefore the normal voltage drop across the 100K resistor is only 0.2V. Nothing really wrong about this.
I am current working on a design I use less than 20uA emitter current and the transistor I use BC550 beta of about 450!
Maybe the transistor is shorted, but with a 100 K emitter resistor, you would not know.
Try reducing the 100 K emitter resistor to 1 K.
what kind of transistor is it?
some have leads in sequence EBC, others in sequence ECB
voltages are in agreement with transistor's base & collector leads swapped .
ie V+ is going to base and Vin to collector.
Would you expect to measure the "correct" voltages with an cheap multimeter, for those low currents? I don't think so.
For a simple demo of how an emitter follower is supposed to work, an emitter current of 20mA would be more practical to work with than 20μA.
I just got my circuit running and measure every single voltage with a $39 cheap DVM. Yes, my DC bias resistor is 510K and tail current of 20uA. I am working on guitar electronics that run on 9V or even watch batteries. Also the magnetic pickup characteristic of guitar change with loading resistor. It has to be between 250K to 500K and all electronics has to accommodate these high impedance and low current design. This is nothing new.
1. How do I know if the transistor in my emitter follower circuit is burned out?
To determine if the transistor in your emitter follower circuit is burned out, you can use a multimeter to measure the resistance between the collector and emitter terminals. A very high resistance or an open circuit indicates that the transistor is likely burned out.
2. What are the common causes of transistor burnout in an emitter follower circuit?
The most common causes of transistor burnout in an emitter follower circuit include excessive heat, overvoltage, overcurrent, and incorrect wiring or connections. These can cause the transistor to overheat and fail.
3. Can a burned out transistor be repaired?
In most cases, a burned out transistor cannot be repaired and will need to be replaced. However, if the cause of the burnout was a temporary overload, the transistor may recover after the overload is removed.
4. How can I prevent transistor burnout in my emitter follower circuit?
To prevent transistor burnout, it is important to select a transistor with the appropriate voltage and current ratings for your circuit. You can also use heat sinks to dissipate excess heat, and ensure proper wiring and connections are made.
5. Can a burned out transistor affect other components in the circuit?
Yes, a burned out transistor can affect other components in the circuit. This is because it can create an open circuit or cause a short circuit, which can affect the flow of current and voltage in the circuit. It is important to replace a burned out transistor as soon as possible to prevent further damage to the circuit.
  • Electrical Engineering
