Cable car and counterweight forces problem. (Tension)
The discussion revolves around a physics problem involving a cable car and a counterweight on a hill. The cable car, weighing 2060 kg, descends a 200-meter hill at a 30-degree angle, while the 1890 kg counterweight ascends at a 20-degree angle. The participant successfully calculated the braking force needed for the cable car to descend at a constant speed as 3759 N. They encountered challenges in determining the acceleration and velocity of the runaway cable car after brake failure, ultimately realizing that both vehicles share the same acceleration due to their connection. The discussion emphasizes the importance of correctly setting up equations for forces acting on different masses and maintaining consistent sign conventions.
Sentience
The 2060 kg cable car shown in the figure descends a 200-m-high hill. In addition to its brakes, the cable car controls its speed by pulling an 1890 kg counterweight up the other side of the hill. The rolling friction of both the cable car and the counterweight are negligible.
The hill that has the 2060 kg cable car descending is 30 degrees. The tip of the triangle is 200 m high, and then the hill that has the ascending 1890 kg counterweight is angled at 20 degrees.
Question 1 : How much braking force does the cable car need to descend at constant speed?
Question 2: One day the brakes fail just as the cable car leaves the top on its downward journey. What is the runaway car's speed at the bottom of the hill?
I'm not sure if this image link will work : http://session.masteringphysics.com/problemAsset/1073561/3/knight_Figure_08_39.jpg
F = ma
Ok, there are 3 forces acting on the cable car. Sin30*mg being the force of gravity, with direction down the incline, the force of the breaks pointed up the incline, and the Tension on the cable from the counterweight on the other side of the hill.
There are only 2 forces acting on the counterweight. They are Sin20*mg and the force of tension on the cable. Because the mass of the cable car is greater, it's pulling the counterweight over and down the hill.
First I found (I think) the force of the breaks.
Total forces on cable car = Ft+Fb-sin30*m*g
Total forces on counterweight = Ft-sin20*m*g
To find the the force on the breaks I set equation 2 as: Tension = sin20*m*g and I get approx. 6335 N. Then I inserted it into the equation for the cable car and set acceleration = 0 since the problem mentioned constant speed.
I then subtract that from the force of gravity on the cable car (sin30*m*g = 10094 N) and get Force of breaks = 3759 N
When I submitted that answer I was correct.
However, I'm completely lost on how to find the acceleration so I can then find the velocity using a kinematic equation. Please help.
Part 2 is pretty analogous to part 1. You did the right thing in setting both accelerations to 0. But now in part two, that acceleration is not 0 but it is still the same for both cars (since they are connected by rope). That should allow you to connect the two equations.
a is longer zero, but Fb is. So is this the right equation?
Ft-sin30*m1*g +T - sin20*m*g = m1a + m2a
Some of the signs don't look right. The tension should cancel.
I was inconsistent with my signs on my axis for each mass, I found the right answer. Thanks for the second set of eyes!
It should have been -T + sin20*m*g on that second equation.
For future reference, if you have multiple forces in different directions acting on a mass do you set your equations as Larger force minus smaller force?
That way you always end up with a positive net force.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
