Calculate Christoffel Symbols of 2D Metric
Ryomega
Consider metric ds2 = dx2 + x3 dy2 for 2D space.
Calculate all non-zero christoffel symbols of metric.
\Gammajik = \partialei / \partial xk \times ej
Christoffel symbols, by definition, takes the partial of each vector basis with respect to component (in this case xk).
So my instinct tells me to differentiate the metric with respect to x and y. Which would give me:
metric differentiated with respect to (x) = 3x2 x1
metric differentiated with respect to (y) = 0 x2
Did I do this right or did I get this completely wrong? If I have done it wrong, please explain.
Thank you very much in advance.
Do you know the equation for calculating the christoffel symbols from the partial derivatives of the components of the metric tensor? Alternatively, for this problem,
ex=ix
ey=x(3/2)iy
and
ex=ix
ey=x(-3/2)iy
where ix and iy are unit vectors in the x- and y-directions, respectively.
Hello! Thank you for the quick reply!
The equation you have mentioned, the only equation I am aware of for relating christoffel symbols to the metric is:
\GammaLab = \frac{1}{2} gLc (gac;b + gcb;a - gba;c)
I'm having a hard time understanding the indices, thus just how to use this equation correctly. I'll give it a go and see if I can't arrive at the same answer.
Thanks again!
Thanks again!
Those should be commas (indicating partial differentiation), not semicolons.
For this problem, it would probably be easier to use your original formula. There are only two dimensions, so there are going to be only 8 gammas to evaluate. Either way, it shouldn't be much work.
chet
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
