math111 said:
Update for givens:
1.Material S/S 304
2.Density(0.29 lbs/in3)
3.Specific Heat(0.12 BTU/lb/°F)
4. 12" width x 12" length x12" height(solid)
5. It is indoors but if you could expand this to a fan in front blowing on it that is something I would like to know how to include this if I know the CFM.
6. The input is uniformally distributed on both sides.
7. Emssivity: 0.075
I'm not sure exactly what you are trying to set up, or how to get the answer to what you ask, but some thoughts in my mind for heating in a uniform method,...I would convert AC to DC and control amps, 208volts@19.230amps = 4,000 watts. A proper sized hole of some depth, to receive a (firm) press fit conductor wire, in the center of each surface (6).
The block of SS will weigh just about 501 pounds, a minimum shaft diameter, three point support, with (almost) pin point tips, to minimize any heat transfer. Height above floor?
http://en.wikipedia.org/wiki/U-factor
A fan blowing air past the block, will produce a thermal transfer from the block, that will require difficult calculations (beyond my ability or time).
Someone else might step in, but as I see in my mind,...if the fan is blowing straight at the block,
1. front surface, heat will radiate away from and toward the fan, the air flow will appear to be flowing over an umbrella, with little motion of air in the central area. Heat will move outward from surface and fold into the air flow, as it moves along the four sides.
2. thermal transfer from the sides, will have a different rate due to the preheat in the air flow, from the frontal heat discharge, the air flow will continue to increase in temperature as it moves along the four sides.
3. as the air flows past the four sides and some distance beyond the rear block surface, there should be a dome like area of thermal heated air (normal low pressure draft area) I'm not clear in my thoughts if heat from the block will make this a positive pressure area in relation to the air flow as it passes the sides, or how far down stream a swirling, mixing effect will be taking affect.
Just a few thoughts, if I'm not too for wrong, this might give you a bit of insight of what might make u-factors hard to calculate.
The other thing I noticed in the link, was thermal radiation factor had 12.11~45.0 ? you gave 304 as a grade, maybe it has a set rate, I did not look.
Your block will for sure not have a uniform temperature. I think.
Ron
