Calculate the charge of a density distributed along z axis?
flux!
How do I find the total charge from a material with a charge density given by
\rho =10^{-9} \text{cos}\left ( \frac{z}{z_0}\right ) C/m^3
that exist between \frac{-\pi}{3}z_0<z<\frac{\pi}{3}z_0.
None I can think of.
Attempt #1:
Since the charge density is a volume charge density we may assume that we are dealing with a cylindrical charge distribution that remains the same along r. However, the radius of the assumed shaped was not given, so let us assume that its radius is r_0. We may solve this by:
q=\int_V \rho d\tau q=\int_0^{r_0} \int_0^{2\pi} \int_{\frac{-\pi}{3}z_0}^{\frac{\pi}{3}z_0} 10^{-9} \text{cos}\left ( \frac{z}{z_0}\right ) C/m^3 rdrd\phi dz
Everything will then be straight forward, but the issue is that
1. r_0 is not given, and
2. the problem did not say it is a cylindrical charge density.
This is just, however, one way I could deal with a volume charge density that does not have a given volume, unusual huh.
Attempt #2:
Since the problem indicated that the volume charge density is distributed on a line, then it must be a line charge only. Thus it must have an infinitesimal radius that could be resolve by Dirac Delta function, so:
must be equivalent to:
\rho =\delta(r,\phi - r',\phi')10^{-9} \text{cos}\left ( \frac{z}{z_0}\right ) C/m
then, things could now be easily solved in the integral:
q=\int_V \left (\delta(r,\phi - r',\phi')10^{-9} \text{cos}\left ( \frac{z}{z_0}\right ) C/m\right )d\tau
4. My Question
Now, my question is, which two approaches is the right solution, Or if neither any of the two is correct, how should we solve the total charge of a density given above?
Cross-Link: Posted the Question In physics.exchange but, does not seem to get answered, Hope you guys help me out. http://physics.stackexchange.com/questions/240215/how-to-compute-the-charge-of-a-density-distributed-along-z-axis
You are specifically given units of C/m3 ... so this is explicitly a volume charge density.
The only dpendence given is z, so a cylindrical symmetry is reasonable.
The question appears to call for the total charge between two planes so ##r\in [0,\infty)## ... but that gives you an infinite charge.
It follows that there is some information missing from the problem statement, or the statement is in error.
You need to use the context that the question is set into further determine the limits for the volume.
Hi, that what all the problem given. No r for a cylinder or so. The problem just tells that the charge is distributed on z.
That's why I suggest going to the context - sometimes the needed information is not explicitly given.
Maybe the "material" is finite in a way mentioned elsewhere?
There are too many other possibilities to safely guess ... which is basically what you are doing above.
Have you asked the other students to see how they are handling it?
If you cannot ask anyone, and you must turn in something, then you will have to just leave ##r_0## as a variable.
I see no need to assume it is a cylinder. Just assume the cross-sectional area in the XY plane is constant, A.
However, this still leaves such a trivial problem that I suspect the missing information is crucial.
Thanks for the responses! I will just assume that there might be a missing information. In case there is none, is my solution involving dirac-delta correct?
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
