Calculate the entropy for a power plant
Calculating the entropy for a power plant requires specific data, including net power output, fuel type and amount, energy consumed by auxiliary equipment, stack gas losses, temperature readings at various locations, and heat rejection rates. Attempts to obtain this data from several power plants were unsuccessful, and the suggested NRC website did not yield useful information. A recommendation was made to inquire about coal-fired plants for potentially better responses. Additionally, a resource titled "Chemical Thermodynamics at a Glance" by H. Donald Brooke Jenkins was mentioned as a helpful reference. Access to accurate data is crucial for the entropy calculation process.
skysurani
i have to calculate the entropy for a power plant. to calculate entropy i have to get some data for the power plant
1.) net power output
2.)the type and amount of fuel
3.)the power consumed by the pumps, fans and other auxiliary equipment
4.)stack gas losses
5.) temperatures at serveral locations
6.) the rate of heat rejection at thecondenser
i call few power plant but they told me that they can give this information and they told me that i can visit the www.nrc.gov[/URL] and try to find information from this site but i didnt find anythings there. if anybody now the site where i can find data or the power plant or if anyone has this data please let me know as soon as possible
thank you
Maybe if you asked about one of the coal fired plants you would get some answers. :smile:
I found the book "Chemical Thermodnynamics at a Glance" by H. Donald Brooke Jenkins particularly useful.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
