Calculate the lifetime of the theta meson
FateEternal
A newly discovered Θ meson has a rest mass energy of 1020 MeV, and electric charge of 0, and a measured energy width of 4 MeV
a Using the uncertainty principle, calculate the lifetime of the Θ meson
b A Θ meson at rest decays into K+ and K- mesons. Find the total KE of the kaons
Thanks
and if you can also help explain the uncertainty principle
the uncertainty principle stems fromthe fact every particle is described by a wave packet of probability density.
the wave-number (k=\frac{2 \pi}{\lambda}) of this packet is the momentum.
when you try to make a wave packet defined in space, you need to add lots of monochromatic waves with different wave-numbers togethere - and when you got only one monochromatic wave (meaning there is only one wave-number) the wave looks like a sine which comes from minus infinity and continues to infinity. meaning you got undefined coordinates for the particle..
so the particle can be described as
\Psi (x)=\Sigma C_ne^{ik_nx}
by using Fourier transform from x to k (when given the shape of particle packet in space) you could see that the minimum value of \Delta x\Delta p=\frac{1}{2}
(when \hbar=1, not in cgs)
energy and time are related to each other the same way as space and momentum, since a Fourier transform of x to t when \Psi (x)=\Sigma C_ne^{ik_nx} will give you the \Psi (t)=\Sigma U_ne^{iE_nt}
so if you know the energy width of the particle, youd know the time width.
by \Delta E\Delta t >= \frac{\hbar}{2} in cgs.
if you want more info look here http://zebu.uoregon.edu/~js/21st_century_science/lectures/lec14.html
wouldnt it be ^E^t>h/2pi?
well, \hbar=\frac{h}{2\pi}
so it would be greater then \frac{h}{4\pi}
but \Delta x\Delta p roughly equals to \frac{h}{2\pi}
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
