Calculate the work done by the force
To calculate the work done by the force on a particle moving along the curve defined by y=ax^2 - bx, where a=2.0 m^-1 and b=4.0 m, the force is given as F=cxy i + d j with c=8.0 N/m^2 and d=16 N. The work done can be expressed as the integral of the force over the path, W=∫F·ds. The next step involves calculating the integral by substituting the expressions for F and the differential path element ds. This requires evaluating the integral with respect to the defined limits from the origin to the point (3m, 6m). The discussion emphasizes the importance of setting up the integral correctly to find the total work done.
pph1011
A particle moves from the origin to the point x=3m, y=6m along the curve y=ax^2 - bx , where a = 2.0m^-1 and b = 4.0m . It is subject to a force F=cxy i + d j , where c= 8.0N/m^2 and d= 16N .
Work is defined as:
\int\vec{F}d\vec{x}. Do you know what's next?
what's the next?
pph1011 said:
what's the next?
Take the integral of work.
W=\int Fds \rightarrow W = \int\int F dx dy
Catch my drift?
