Calculate velocity components x,y and z
To calculate the velocity components x, y, and z in a 3D environment based on a velocity value and two angles (yaw and pitch), one must relate pitch to the x-axis and understand the implications of spherical coordinates. The discussion highlights that yaw is along the z-axis, while pitch is typically considered as the angle from the horizontal plane. The user seeks to develop a Java program that calculates the trajectory of a thrown ball, including the time until it hits the ground and its x and y coordinates. There is a consensus that translating initial conditions into velocity components is essential, and learning about spherical coordinates may be necessary for clarity. Overall, the conversation emphasizes the importance of understanding the relationships between the axes and angles in 3D motion.
Redweasel
Hello,
I want to calculate the velocity components x, y and z based on a velocity value and two angles (yaw along the z-axis and pitch).
I know how to calculate the x and y components in an 2D-environment:
initial velocity x = initial velocity * cos(theta)
initial velocity y = initial velocity * sin(theta)
But I can't figure out to apply this to an 3D-environment. Can anybody give me some good resources for learning this concept or provide some examples?
Many thanks in advance!
Redweasel
P.S.: Sorry for my bad english
If the yaw is relative to z axis, then which axis is pitch relative to? This sound similar to spherical coordinates, with r equal to the magnitude of velocity. Note that there are conflicting usages of the symbols used to represent the angles. Link to mathworld article:
http://mathworld.wolfram.com/SphericalCoordinates.html
The pitch should be related to the x axis.
The purpose for this is java programming. I want to create a little program where you enter the initial velocity, yaw and pitch and then throw a ball. It then displays the time when it hits the floor (time = zInitialVelocity / g * 2) and the x and y coordinates. Is there a way without the spherical coordinate system?
Related to the x-axis in which direction, towards the y-axis or towards the z axis? You didn's specify the relationship bettween x, y, z axis and the directions left-right, forward-back, up-down. If z-axis is vertical, then pitch could be the angle from horizontal (the x-y plane) (which could be restated as π/2 - angle from z-axis), and yaw would be the angle from x or y-axis along the x-y plane.
A velocity, yaw, and pitch implies a spherical like coordinate (magnitude and two angles). You can always translate the initial condition into components of velocity vx, vy, vz. Acceleration can also be split up into ax, ay, az components and position would be x, y, z.
I guess I have to learn this spherical coordinate stuff then. Looks quite confusing, but I think I'll find a way. Thanks for your answer
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
