Calculate Volume of Enclosed Region with Cylindrical Coordinates
The discussion revolves around calculating the volume of a region defined by the surfaces z = x^2 + y^2 and z = 2x, utilizing cylindrical coordinates for the integration process.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to establish limits of integration in cylindrical coordinates and seeks verification of their correctness. Some participants discuss the geometric interpretation of the surfaces involved and the intersection points in the xy-plane.
Participants are engaged in verifying the limits of integration and the setup of the problem. There is acknowledgment of the use of cylindrical coordinates, and some guidance has been provided regarding the geometric relationships between the surfaces.
There is a focus on ensuring the correct interpretation of the surfaces and their intersection, with some participants expressing uncertainty about their understanding of the problem setup.
Imo
"Find the volume of the region enclosed between the survaces z=x^2 + y^2 and z=2x"
I figured that the simplest way of doing this was to switch to a cylindrical co-ordinate system. Can someone check that the limits of integration are then
-\frac{\pi}{2}\leq \theta \leq\frac{\pi}{2}
0\leq\ r \leq 2\cos(\theta)
r^2\leq\ z \leq 2 r \cos(\theta)
(and the jacobian being r)
Thanks greatfully
z= 2x is a plane and forms the top of the figure. You are correct that you should use cylindrical coordinates. But z= x2+ y2 is a paraboloid. it's interesection with z= 2x is z= 2x= x2[/wsup]+ y2 or x2- 2x+ 1 + y2= (x-1)2+ y2 = 1 which, projected down into the xy-plane is the circle with center (1,0) and radius 1. In cylindrical coordinates, x2+ y2= 2x is r2= 2rcos θ or
r= 2 cos &theta. THAT is the fomula you need.
Unless I'm missing something (which is entirely possible), is that not what I have?
Yes, I believe your limits of integration are correct.
  • · Replies 21 ·
