Calculating average acceleration during a time interval
5 replies · 2K views · last reply
naushaan
A car initially travelling eastwards turns north by travelling in a circular path at uniform speed as in the figure below. The length of the arc ABC is 240 m, and the car completes the turn in 34.0 s.
(a) What is the acceleration when the car is at B located at an angle of 35.0°? Express your answer in terms of the unit vectors î and ĵ.
(b) Determine the car's average speed.
(c) Determine its average acceleration during the 34.0 s interval.
I've calculated (a) and (b) but not sure how to attempt (c)
a=v^2/r
v=l/t
Diagram of a car moving along a quarter-circle arc from A at the origin on the y-axis, through B at 35.0 degrees from the y-axis, to C on the positive x-axis, with red arrows showing the velocity at A and the acceleration at C.
Here's my calculations for (a) and (b)
Handwritten working on a circular arc: arc length 240 m, time 34 s, angle 35 degrees; arc length for 90 degrees, speed 11.09 m/s, centripetal acceleration 0.51 m/s^2, and acceleration vector (-0.291i + 0.42j) m/s^2.
Relevant Equations:: a=v^2/r, v=l/t
Hi,
Actually, your relevant equations give a hint: you provide one equation for the instantaneous acceleration (during a circular trajectory at constant speed) and one for the average speed (over a straight section).
If you can work around the expression $$ v_{average} = {\Delta {\sf position}\over \Delta \sf time}$$(bearing in mind that position is a vector !) to something similar for average acceleration, you are in business
A question:
Handwritten working in blue: "a. L OF ARC IS FOR A 90° OR π/2 RADIANS IS: L = rθ = 240(π/2) = 376.99"
If the problem statement says
why do you not believe that and calculate something else ?
BvU said:
A question:
If the problem statement sayswhy do you not believe that and calculate something else ?
thank you for your response! I don't understand what you mean by this.
It is much more convenient to respond when your work is typed in. It is then possible to quote it. The same applies for the problem statement.
We are told that "The length of arc ABC is 240 meters". You have calculated:
re-typed by hand said:
a. L of arc is for A 90 degrees or pi/2 radians is: ##L=r_0 = 240\frac{\pi}{2}=376.99##
So constant speed is ##v = \frac{L}{t} = \frac{376.99}{34} = 11.09 \text{m}/\text{s}##
That would be correct if what we were given were a radius. But we were given an arc length.
In case it helps, I decoded this for my self,
a. L of arc is for A 90 degrees or pi/2 radians is: ##L=r_0 \frac {\pi}{2} = 376.99 \, \,\, \, \text { So constant speed is }v = \frac{L}{t} = \frac{376.99}{34} = 11.09 m/s ##
That would be correct if what we were given were a radius. But we are given an arc length.
What seems to have happened: you were told the arc length but not the radius.
You thought it was the radius and calculated the corresponding arc length.
You needed to do the opposite - take their arc length and find the radius.
