Calculating CFM for Compressed Air Venting Down to Atmospheric Pressure
The discussion focuses on calculating the time it takes for a compressed air cylinder at 150 PSI and a volume of 7.3 cu in to vent to atmospheric pressure through a 1.77mm opening. The user is struggling to understand the need for air velocity in determining CFM and how to calculate that velocity since many resources seem circular. They mention the complexities of the problem, including non-linear dynamics and the cooling of gas, and refer to relevant equations like Boyle's Law and Bernoulli's equation. Despite initial confusion, they express progress in understanding the calculations, although the results seem implausible, indicating further refinement is needed. The conversation highlights the challenges of fluid dynamics in compressed air venting scenarios.
Nuttypro67
Hello gentlemen! I'm rather new to this whole complex world we call compressed air. :) Put simply, I have spent the past 4 hours trying to find this answer anywhere and I am just not informed enough about all these numbers to get what I need to find out.
I have an air cylinder that is compressed to 150 PSI with a volume of 7.3 cu in. I am trying to find out how long it will take for the 150PSI to vent down to atmospheric pressure through an opening that is 1.77mm in diameter.
I realize I need to find CFM, Cubic Feet per Minute. But everywhere I look the calculator asks for velocity of the air. For some reason I just can't grasp why you would need the velocity of the air to figure out how much is moving through the opening. Nor do I have any idea how to figure the velocity since all the velocity equations I found are asking for the CFM!
Thanks guys!
I was going to post that same link. The difficult part of finding the leak time for a pressure vessel is the fact that it is a highly nonlinear coupled problem (the gas is cooling, the pressure is changing, and the flow rate may or may not be choked flow, etc...). You best bet for a plug-and-play answer are the equations provided in the posted link.
It is a fluid dynamics problem...
see;
Boyle's Law
Google;
blowdown air orifice
blowdown orifice flowrate
For critical flow, see;
http://www.cheresources.com/high_dp_orifice_flow.shtml
Some of the complexities are considered here;
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=JPVTAS000131000003034501000001&idtype=cvips&gifs=yes
Hope this helps.
hmmm, well I THINK I got the equation to work but the results its kicking out just don't make any sense.
According to the results, it will take 788,153 seconds or 9 days for the vessel to reach 50% density. Haha!
Thanks a MILLION for the equation, though. I am now 10 times closer to my answer than I was yesterday. You guys are great. :)
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
