Calculating change in angle from an impulse force
To determine the maximum angle a rifle raises after firing, one must consider the force of the bullet, the gun's weight, and the distances from the center of mass to the pivot point. The initial angular velocity can be calculated using conservation of angular momentum, given the bullet's velocity and the gun's mass distribution. Energy conservation principles can then be applied, where the initial rotational kinetic energy equals the change in potential energy at the highest point of the barrel's arc. The maximum angle can be calculated by analyzing the geometry of the barrel's movement from its original to final position. This approach effectively combines principles of physics to solve the problem.
jacobh
say there was a rifle that pivoted about the center of its butt..
if you knew the force from the bullet, the weight of the gun and its center of mass, the distance from the center of the barrel to the center of the butt, and the distance from the center of gravity and the center of the butt, how would you go about determining the maximum angle the gun raises after firing?
i'm a little stumped. i don't recall doing any problems like this back in school, so any help would be appreciated :-p
by the way, assume that no other forces acting upon the gun (no hand holding the forearm)
You need to know the perpendicular distance from the line of the barrel to the point of rotation. If you know the velocity of the bullet, you can use conservation of angular momentum to get an initial angular velocity for the barrel. You need a reasonable model for the mass distribution of the barrel and stock to calculate the moment of intertia about the bivot point.
so how can i get the maximum angle from angular velocity?
You could use energy conservation for that. If you know the angular velocity imparted to the barrel from angular momentum conservation, the barrel will have rotational kinetic energy about the pivot point. As the CM of the barrel raises, its potential energy increases and the kinetic energy decreases. At the highest point, the kinetic energy is zero and the change in potential energy equals the initial kinetic energy. Calculate the angle from the geometry of the original and final lines of the barrel.
