Calculating Distance Deflected by Earth's Magnetic Field for 3.4g Bullet
To calculate the deflection of a 3.4g bullet moving at 160 m/s in Earth's magnetic field, the formula r = mv/qB is applicable, where m is mass, v is velocity, q is charge, and B is the magnetic field strength. The bullet's charge is 13.5 x 10^-9 C and the magnetic field strength is 5 x 10^-5 T. The confusion regarding the angle is unnecessary since the bullet's motion is perpendicular to the magnetic field. After traveling 1 km, the deflection can be determined using the correct application of the formula. The problem was ultimately resolved with the right approach to projectile motion.
TickleMeElma
A 3.4g bullet moves with a speed of 160 m/s perpendicular to the Earth's magnetic field of 5x10^-5T. If the bullet possesses a net charge of 13.5 x 10^-9 C, by what distance will it be deflected from its path due to the Earth's magnetic field after it has traveled 1 km?
I am confused. Do I use r=mv/qB? Do I need an angle? I am confused by the way this question is phrased. Plsease help!
Thanks.
i forget the exact way of doing this problem, but i remember that it involves projectile motion
Thanks so much for your input. I solved it, you were right. :)
