Calculating Electric Field at the Center of a Hemispherical Shell of Charge
The problem involves calculating the electric field at the center of a hemispherical shell of charge, derived from a hollow sphere with a uniform charge distribution. The context is rooted in electrostatics, specifically focusing on the application of integration and Coulomb's law.
  • Participants discuss the necessity of using spherical coordinates for integration and the challenges in setting up the integral. There are mentions of the limitations of Gauss's law due to the lack of symmetry in the problem. Some participants suggest considering the charge density and the forces on a test charge at the origin.
The discussion is ongoing, with participants sharing hints and approaches without reaching a consensus. Some guidance has been offered regarding the use of spherical coordinates and the integration process, while others express their eagerness to tackle the problem further.
Participants note the constraints of not having access to reference materials, such as a calculus book, which may affect their ability to set up the integration correctly. The problem is due soon, adding a sense of urgency to the discussion.
swervin09
A hollow sphere of outer radius R2 and inner radius of R1 carries a uniform charge 2Q. The sphere is then cut in half to create a hemispherical shell of charge Q. Calculate E at the center point (origin) P.
equation of a hollow sphere = 2/3π(r2-r1)
Gauss' Law ∫E dot dA
surface area hemisphere = 2πr^2
Well, I know this is an integration problem and that I am better off integrating with polar coordinates and that I will be integrating from 0-->π as my lower and upper integral bounds.
But in all honesty I haven't had much fortune setting the integral up. The set up is the help I am asking for.
If I am not mistaken, you need to find the E field due to a HEMISPHERICAL shell
That involves some somewhat-complicated multiple integrals and E form Coulumb's law. Gauss's law will not work due to lack of symmetry
Assuming that that is your problem, here is my hint:
Use spherical coordinates. find the charge density. consider an infinitesimal piece of the shell and the Coulomb force on a test charge at the origin. Then choose appropriate limits for r, theta, and phi and integrate
Yes that is the problem. spherical coordinates make more sense. I will try that and post tomorrow what I have come up with. I don't have my calculus book nearby to refresh my memory of spherical coord. integration. This is one of those problems that has me intrigued and eager to "beat". It isn't worth a lot of points but it is due Thursday.
Thank you for the hint!
no problem!
I might add: depending on how comfortable you are with multivariable, you don't have to use a triple integral; just find the field of a ring, sum into a washer, sum the washers into a shell. The spherical coordinates are just a way of thinking, no need to get formal about it
I follow you up until you state sum the washers into a shell. Please provide a hint as to that specific.
