Calculating Electric Field due to a Dipole
To calculate the electric field at location A due to two dipoles, the relevant equations are (1/4*pi*epsilon)*(2qs/d^3) for the dipole axis and (1/4*pi*epsilon)*(qs/d^3) for the perpendicular axis. The values provided include q = 4 nC, s = 1 mm, and d = 6 cm. The user calculated the x component as 166 N/C and the y component as 333 N/C, but received feedback indicating the results were incorrect. The discussion highlights that the electric field direction is influenced by the proximity of charges, with the net field being the sum of contributions from both dipoles.
guitarman
Two dipoles are oriented as shown in the diagram below. Each dipole consists of two charges +q and -q, held apart by a rod of length s, and the center of each dipole is a distance d from location A. If q = 4 nC, s = 1 mm, and d = 6 cm, what is the electric field at location A?
As I am unaware of how to attach a file, here is a diagram
+--------------A
the *s are there for formatting, or the else lines do not align
(1/4*pi*epsilon)*(2qs/d^3) is the electric field of a dipole, on the dipole axis
and
(1/4*pi*epsilon)*(qs/d^3) is the electric field of a dipole, perpendicular to the dipole axis
Plugging the values given, I used the latter equation for the x component, and by doing (9e9)(4e-9*1e-3)/(6e-2)^3 I obtained 166 N/C.
I used the first equation for the y component and obtained 333 N/C
I know there is no z component, so I input <166, 333, 0> N/C, yet this is wrong. Can somebody explain to me what I am doing? I attempted submitting -166 for the x component in case I had somehow misinterpreted the direction of the field, but that was also wrong. Does anybody understand what I am doing wrong?
In the dipole above A, the negative charge is closer to A . So the attractive force is more than the repulsive force. So the electric field is towards the dipole.
In the equatorial position the direction of the field is parallel to the dipole from positive charge to negative charge.
Hence the electric field due to two dipoles are in the same direction. So the net field is the sum of them.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
