Calculating electric flux with a constant electric field
The discussion focuses on calculating electric flux through the bottom of a car in a vertical electric field of magnitude 2 x 104 N/C. The car's dimensions are 3.00 m by 1.50 m, and it is traveling at a downward angle of 7°. The correct formula for electric flux, Eflux = E * (A cos θ), yields a result of 89,329 Nm2/C, confirming the calculation is accurate. The brewing thunderstorm is noted as a contextual element but does not affect the mathematical approach to determining electric flux.
  • Understanding of electric fields and their properties
  • Familiarity with the concept of electric flux
  • Knowledge of trigonometric functions, specifically cosine
  • Ability to perform basic area calculations for geometric shapes
  • Study the derivation of the electric flux formula Eflux = E * (A cos θ)
  • Explore the effects of varying angles on electric flux calculations
  • Learn about the relationship between electric fields and atmospheric phenomena
  • Investigate applications of electric flux in real-world scenarios, such as in thunderstorms
Students in physics, particularly those studying electromagnetism, as well as educators and anyone interested in practical applications of electric field concepts.
NewtonianAlch
A vertical electric field of magnitude 2 X 10^4 N/C exists above the Earth's surface on a day when a thunderstorm is brewing. A car with a rectangular size of 3.00 m by 1.50 m is traveling along a dry gravel roadway sloping downward at 7.0°. Determine the electric flux through the bottom of the car.
Eflux = E*(A cos theta)
(2*10^4)*(3*1.5)*(cos 7) = 89,329 Nm^2/C = 8.93*10^4 Nm^2/C
Is this correct? It seems pretty straightforward to me, but I can't help think that there is some trick in the question that I'm not seeing.
Flux through a surface perpendicular to the electric field obviously has cos 90 = 0 as the angle angle associated with it so it would just be Eflux = E*A, but there is an angle here, so it would simply be cos 7. Does the thunderstorm brewing have any bearing on the equations affecting the answer?
It seems the thunderstorm that is brewing is the source of the E field, and is just a little back story.
Have a quick thought about it. The X flux is the amount of X going through a surface area, correct?
If the field is uniform and vertical, will there be a difference between the flux through a horizontal surface A and a surface B, if surface B's horizontal componant of area (oh gawd did I just slaughter that phrase, but I hope you get my point) is the same as surface A?
For example, if there is a sheet area 1m by 3m held horizontally in a rain storm (assuming uniform vertical rain) will it's dry patch be the same area as a 1m by 5m sheet held at 53* (or whatever the angle in a 3,4,5 triangle is)?
So you are really just finding the surface area seen by the uniform field, then multiplying that by the strength of that field. It is very simple.
