Calculating Gas Pressure in a Piston System with Added Weight
The discussion focuses on calculating gas pressure in a piston system when a 0.5 kg weight is added. Initially, the gas pressure is 1 atmosphere at 300 Kelvin. The pressure exerted by the weight is calculated using the formula \( P = \frac{F}{A} \), where \( F \) is the force due to the weight (4.9 N) and \( A \) is the area of the piston. The volume of gas can be determined using the ideal gas law \( PV = nRT \), but the area of the piston must be known to solve for pressure accurately.
  • Understanding of the ideal gas law (PV=nRT)
  • Basic physics concepts of force and pressure
  • Knowledge of units of measurement (e.g., Newtons, atmospheres)
  • Familiarity with piston systems and their mechanics
  • Calculate pressure using \( P = \frac{F}{A} \) with known piston area
  • Explore the relationship between pressure, volume, and temperature in gas systems
  • Learn about the effects of varying weights on gas pressure in piston systems
  • Investigate how to manipulate the ideal gas law for different scenarios
Students studying physics, engineers working with pneumatic systems, and anyone interested in thermodynamics and gas laws.
dragon162
Suppose the system is at room temperature, 300 kelvin, and that before we put weights on top of the plunger in the cylinder the pressure inside is 1 atmosphere.
1)If i place a .5kg block on top of the piston, what is the pressure of the gas inside the cylinder?
2)At that pressure what is the volume of the gas?
3)If i want to have L=0cm what should the pressure be?
4)how much mass would we have to pile on top of the piston to achieve that pressure inside the system?
PV=nRT
Volume of piston is V=L*A
Ok I am confused as how to find the pressure of the gas when the block is added to the piston. Since the block is on the piston doesn't it apply a pressure of mg, (.5kg)(9.8)=4.9?
The second part is obvious, just use PV=nRT but I have to find the pressure in part 1 first. As for the other two I don't know how to start them but I am focused on the first part right now.
bumpy bump help please
mg would be a force, not a pressure. The block applies a force of mg. To get the pressure, you would need to know the area of the piston's face. Without that information, the problem cannot be solved.
  • · Replies 67 ·
11K
