Calculating Gear RPM: Understanding Tire and Shaft Rotation | 60 Tooth Gear
The discussion focuses on calculating the RPM of a 60-tooth gear based on the rotation of an 8.4" tire at 0.68 RPM. It is established that if the tire rotates at 0.68 RPM, the connected shaft will also rotate at the same RPM, leading to the conclusion that the gear will match this speed as well. Participants emphasize that both the tire and gear rotate together, with the understanding that a simple universal joint may introduce some speed oscillation, but does not affect the overall RPM equality. The mental exercise proposed illustrates that both the tire and shaft make the same fraction of a revolution, reinforcing the concept of equal RPM. Ultimately, the tire, gear, and intermediate components will all rotate at the same speed under these assumptions.
JudahZ
Hey Guys,
So in the attached image I'm trying to determine what the rpm of the 60 tooth gear will be given the 8.4" tire will be rotating at .68 rpm, everything else is just an assumption on my part.
I'm assuming the following which is probably wong:
The tire being rotated at .68 rpm will result in the .5" linked shaft rotating at 11.45 rpm. I'm dividing the circumference of the tire by the circumference of the shaft and multiplying by the rpm of the tire to arrive at 11.45 rpm.
If the .5" shaft is rotating at 11.45 rpm for the purpose of calculations will the 60 tooth gear also be rotating at 11.45 rpm? Sorry, I obviously suck @ life.
Try this as a mental exercise.
1) Put a chalk mark on the tire so you can tell when it makes on complete revolution. (Say at the top.)
2) Put a mark on the shaft at the same place as the mark on the tire. (Again at the top.)
3) Now turn the tire a quarter revolution.
How many revolutions did the shaft make? Don't bother with any math, just think it thru.
Likes billy_joule
well, they both made a 1/4 revolution. So would this mean the shaft & gear is at .68 rpm? lol
Yup, you got it!
Tom.G said:
Yup, you got it!
Thanks man!
Note that with a simple universal joint there will be some speed oscillation between the tire and the gear. Simple universal joints are not constant velocity. If that doesn't matter then the tire and the gear are turning at the same RPM. Everything, including the tire, the 60T gear, the intermediate shafts, the universal joint will be rotating at the same speed.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
