Calculating Magnitude of Force F2 on Mass M
To calculate the magnitude of force F2 acting on mass M, first recognize that the net force can be determined using Newton's second law, F = ma. Given that F1 = 7.0i + 5.0j + 6.0k N and the acceleration a = 1.0i + 3.0j + 3.0k m/s², the net force can be calculated as F_net = M * a = 6.0 kg * (1.0i + 3.0j + 3.0k) = 6.0i + 18.0j + 18.0k N. To find F2, rearrange the equation to F2 = F_net - F1, resulting in F2 = (6.0i + 18.0j + 18.0k) - (7.0i + 5.0j + 6.0k) = -1.0i + 13.0j + 12.0k N. The magnitude of F2 can then be calculated using the formula √((-1.0)² + (13.0)² + (12.0)²).
BrettL789123
Two forces F1 and F2 are acting on a mass M=6.0 kg. The force F1 = 7.0i + 5.0j + 6.0k, in N. The acceleration of the mass is given by a = 1.0i + 3.0j + 3.0k, in m/s2. Calculate the magnitude of F2.
I understand that when adding these forces you just add like terms, the i's j's and k's togehter. but what do you do with accel.? do i just subtract F1 like terms with Acell. like terms? never done a problem like this before.
To subtract one vector from another, you do just subtract their components. However, you must be sure to write the vector equation down correctly to make sure you are subtracting the right vectors (and in the right order). What do you get for this problem?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
